Nov 14, 2023 12:59 PM UTC
Aligned to center text comes out cut
I was placing text into a text area, and no matter what I do, it comes out cut from the sides.
the code:
 textArea1.setTypedText(touchgfx::TypedText(T_ID_PLACE_CART_IN_CARTON));
invalidate();
the result:
I suppose it could be the bounding area, but how can I fix this?
Nov 14, 2023 2:20 PM UTC
Hello @ArthurStone ,
Consider using static size for your Text Area and give it a size large enough to accommodate the text. You can specify the size your self through the designer by unchecking Auto-size.
 I hope this helps you
Mohammad MORADIST Software Developer | TouchGFX
