NS.16
Adding Custom Target Board in Touchgfx
Hi Sir,
I have designed some graphics in stm32f29 using Touchgfx.In stm32f429zi i am going to change the 240*320 LCD to 320*480 LCD by own.So now i want to graphic the board using Touchgfx.
1.Is there any Possible to bring my new changed LCD board in to Touchgfx Target selection Area and design Graphics.
2.How do i program the new board using touchgfx and eclipse.
Warm Regards ,
NAGARAJ S
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
May 13, 2019
  1. If you're talking about how to create your own custom Application Template that you can use from within the designer, you can read this article on how to achieve that: https://touchgfx.zendesk.com/hc/en-us/articles/115002741432-Create-custom-Application-Template
  2. I don't know about Eclipse, but you can get some inspiration from Atollic projects generated with CubeMX.
Hope that helps!
Best regards,
Martin
Martin KJELDSEN
Principal III
May 13, 2019
Hope that helps!
Best regards,
Martin
MLec
December 15, 2020
Hello Martin,
I am afraid that link do zendesk is expired.
Can you provide solution for creating custom board in TouchGFX ?
Thank you in advance.
Martin KJELDSEN
Principal III
December 16, 2020
Hi, yes, we're using https://support.touchgfx.com now.
The general process is to use TouchGFX Generator through CubeMX and there's some guides for how to prepare your board/drivers to run touchgfx. Let me know if you can't find what you seek
