ferro
Lead
Jan 23, 2025 11:48 AM UTC
add function 'setAlignment ()' to set text alignment in TextArea widget
Dear Gfx Team,
Could you please add function 'setAlignment ( touchgfx::Alignment align )' to set text alignment in TextArea widget ?
This would override what is defined in 'typedText_database_XXX[]' arrays in TypedTextDatabase.cpp.
Thank you
GaetanGodart
GaetanGodartBest answer
Jan 23, 2025 3:53 PM UTC
Hello @ferro ,
We will discuss about this feature with the team!
Regards,
Gaetan GodartSoftware engineer at ST (TouchGFX)
GaetanGodart
Hello @ferro ,
Regards,
GaetanGodart
Feb 3, 2025 1:52 PM UTC
Hello @ferro ,
We will add this feature in a future major release.
Regards,
Nex-Leo
Apr 25, 2025 6:35 AM UTC
Looking forward to this new feature of yours, roughly when will it be released please?
GaetanGodart
Apr 25, 2025 8:29 AM UTC
Hello @Nex-Leo ,
This require to change our textArea implementation which is a bit too static right now so do not expect it to be implemented for the current project you are working on.
If you have a specific behavior you want to achieve, we can try to work on it together.
Regards,
