Zwei.9
About scrolllist.
How to solve the problem of slow scrolllist sliding process, when the item template is too complicated(Template size :710*35,contains 4 textAreas�?2 bitmaps 5 boxs,Scrolllist size :710*350).The simulator is very nice,but H7 board is not smooth.
Zwei.9
Zwei.9Best answer
Thank you very much.I found the problem.ADC acquisition task consumes CPU resources extremely, resulting in degradation of UI performance.
Alexandre RENOUX
January 3, 2022
Hello Zwei.9.
Can you share your UI ? Otherwise, it's difficult to give you any feedback.
/Alexandre
Zwei.9
Zwei.9AuthorBest answer
Alexandre RENOUX
January 4, 2022
Hello Zwei.9,
Glad to hear that you fixed your issue ^^
Please close this topic by choosing Select as Best
/Alexandre
