Jpark.41
April 14, 2021
About screen cracking that occurs after generating code of MX file generated by Touch GFX
Using version​ : IDE 1.6.1
GFX Designer: 1.6.1
MX : 6.2.1
Board : STM32L4R9 DISCORVERY
First of all, I am not good at English, so I am posting questions with a translator. Please understand.
I ran into a problem while trying the video below.
https://www.youtube.com/watch?v=4-fyx4e96jk&list=PLvjA8o0qS7pdKl9P9bda6PT2hRw-VQ3c_&index=5
As in the title, after the code is generated by changing the code generated by GFX in MX, running in the IDE, running target in GFX, or both, the screen is broken.
(Phenomena where R G B points appear sparsely on a black screen)
While searching the internet, I found the link below, and I'm not sure if this is the same as what I've been through. And it is a frustrating situation because I am not sure how to apply the method introduced as a temporary solution from the link below.
https://support.touchgfx.com/en/docs/miscellaneous/known-issues
With a camera and display, I'm trying to implement streaming, still-cut photo saving, etc, but I'm stuck. If you have any detailed methods, please help me. We ask for your help.
Thank you.
