DJin.3
Jul 5, 2019 6:49 AM UTC
4.11 Can not create/open project
I check the log, it will pop this error:
System.ArgumentException: 已添加了具有相�?�键的项。(An item with the same key has already been added)
  在 System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
  在 System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
  在 TouchGFXDomainModel.FontGetter.GetAvailableFonts()
  在 TouchGFXDomainModel.LoadSave.Excel.TextDB.ReadFromExcelFile(String path)
  在 TouchGFXDomainModel.LoadSave.Serial.FromSerial.Convert(SerialApplication a)
  在 TouchGFXDomainModel.LoadSave.Serial.FromSerial.Convert(SerialModel m)
  在 TouchGFXDomainModel.LoadSave.LoadSave.Load(String filename)
  在 TouchGFXPackages.ImportExport.ImportGui.GetModel(FileInfo fileInfo)
  在 TouchGFXPackages.PackageManager.CombineAtAndUi(TouchGFXPackage tgui, TouchGFXPackage tgat, String projectPath, String applicationName, Int32 height, Int32 width, ColorDepth selectedColorDepth, Action`2 progress)
  在 TouchGFXDesigner.StartupWindow.MyApplications.CreateNewApplicationViewModel.<>c__DisplayClass89_0.<CombinePackagesAsync>b__0()
  在 System.Threading.Tasks.Task`1.InnerInvoke()
  在 System.Threading.Tasks.Task.Execute()
Martin KJELDSEN
Principal III
Jul 9, 2019 11:10 AM UTC
Hi @DJin.3​,
4.11 isn't out officially, so you must have gotten it from someone here at the office :) Try opening your excel file - is it corrupt? This error, i think, comes from an excel library we're using.
/Martin
