Ebun.1
Senior
April 14, 2021
3 buttons with image
Thank you for helping.
environment:
TouchGFX Ver 4.16.1
Prepare two released images and one pressed image.
While pressed, the pressed image is displayed.
I want to switch the image of the released image every time the button is pressed and released.
How should I implement it?
Thank you.
MM..1
MM..1Best answer
BITMAP_MENU_SEL_ID is from db you use your.
buttonWithLabel1.setBitmaps(touchgfx::Bitmap(BITMAP_MENU_SEL_ID), touchgfx::Bitmap(BITMAP_MENU_SEL_ID));
MM..1
MM..1Best answer
Ebun.1
Ebun.1Author
Senior
April 15, 2021
Hi MM1
I am always grateful for your help.
I didn't understand what it meant, but I could understand it by looking at BitmapDatabase.cpp.
I was able to operate as desired.
Thank you very much.
