ahphong
Nov 10, 2026 9:08 AM UTC
大家好,我遇到了STM32H503CBT6,PROVISIONED后如何恢复OPEN
Edited by an ST Community moderator to translate the content. Please use English in this community. Thank you for your understanding.
当初的操作是:
1. STM32H503CBT6原本处于 OPEN。
2.在STM32CubeProgrammer 2.23.0.0里手动将 PRODUCT_STATE 设置为 PROVISIONING (0x17)。
3. 没有烧录 DA 密码 HASH 到 OTP。
4. 在STM32CubeProgrammer 2.23.0.0里手动将 PRODUCT_STATE 设置为 PROVISIONED (0x2E)。
现在希望恢复 OPEN,我改如何操作?自己设计的最小系统板。
也尝试使用
./STM32_Programmer_CLI.exe -c port=SWD pwd=da_password.bin debugauth=2
得到的结果是
PS D:\software\STMicroelectronics\STM32CubeProgrammer\bin> ./STM32_Programmer_CLI.exe -c port=SWD pwd=da_password.bin debugauth=2
STM32CubeProgrammer v2.23.0
Password file path submitted : da_password.bin
Start Debug Authentication Sequence
Open SDM Lib
SDMOpen : 765 : open : SDM API v1.0
SDMOpen : 766 : open : SDM Library version v1.4.0
open_comms : 606 : open : Asserting target reset
open_comms : 614 : open : Writing magic number
open_comms : 678 : open : De-asserting target reset
open_comms : 713 : open : Communication with the target established successfully
response_packet_lock
discovery: target ID.......................:0x474
discovery: SoC ID..........................:0x00000000_35373436_32345102_00510052
discovery: SDA version.....................:1.2.0
discovery: Vendor ID.......................:STMicroelectronics
discovery: PSA lifecycle...................:ST_LIFECYCLE_IROT_PROVISIONED
discovery: PSA auth version................:1.0
discovery: ST HDPL1 status.................:0x11111111
discovery: ST HDPL2 status.................:0x22222222
discovery: ST HDPL3 status.................:0x33333333
discovery: Token Formats...................:0x00000200
discovery: Certificate Formats.............:0x00000201
discovery: cryptosystems...................:ST Password
discovery: ST provisioning integrity status:0xFFFFFFFF
discovery: ST provisioning integrity status message:UNKNOWN
discovery: permission if authorized...........:(a/14) ==> Full Regression
To select multiple permission/actions:
Using numerical values: List the needed bit numbers, separated by commas without spaces.
Using symbolic letters: List the needed letters by concatenating them without separators.
Debug Authentication: Discovery Success
尝试了几种方法,均无法回归,
方法1:将stlink连接目标板,连接MCU的NRST到stlink的NRST。
使用STM32CubeProgrammer,无法连接,也无法关闭
方法2:尝试将boot0短接到3.3V,再将USB连接到windows PC,MCU无法进入Bootloader,直接运行之前烧录的程序。
测试在没有更改PRODUCT_STATE是可以进入Bootloader。
附上我的原理图。
Translation; by Google translator:
The procedure followed at the time was:
1. The STM32H503CBT6 was initially in the OPEN state.
2. The PRODUCT_STATE was manually set to PROVISIONING (0x17) using STM32CubeProgrammer 2.23.0.0.
3. The DA password hash was not programmed into the OTP.
4. The PRODUCT_STATE was manually set to PROVISIONED (0x2E) using STM32CubeProgrammer 2.23.0.0.
Now I want to restore OPEN, what should I do? The smallest system board designed by myself.
Also try using
The result obtained is
Open SDM Lib
I have tried several methods, but none have succeeded in restoring the device.
Method 1: Connect the ST-LINK to the target board, linking the MCU’s NRST pin to the ST-LINK’s NRST pin.
Using STM32CubeProgrammer, it is impossible to establish a connection, nor is it possible to close the application.
Method 2: I tried shorting `boot0` to 3.3V and then connecting the device to a Windows PC via USB; however, the MCU fails to enter the bootloader and instead proceeds to execute the previously flashed program.
Testing confirms that the device can successfully enter the bootloader when `PRODUCT_STATE` remains unchanged.
I have attached my schematic.
ahphong
ahphongAuthor
Nov 10, 2026 9:15 AM UTC
目前我已经成功PROVISIONED (0x2E) 21块最小核心板了😂,没有多余的了。
怎样才能回到OPEN呢?
I’ve successfully provisioned (0x2E) 21 minimal core boards so far—that’s all of them, I’m completely out! 😂
How can I revert them back to the OPEN state?
