KDJEM.1
KDJEM.1Best answer
Mar 9, 2023 8:27 AM UTC
Hello @SURLEAU.Frederic​ ,
You can find all documentation related to X-CUBE-CRYPTOLIB version 4 in this link and in this wiki.
Also this wiki shared the main changes compared to legacy Cryptographic Library version V3.x.x and helps with the migration of user code to the new Cryptographic Library version V4.x.x.
Thank you.
Kaouthar
KDJEM.1
KDJEM.1Best answer
Thank you.
Kaouthar
anotherandrew
Senior
Aug 10, 2023 12:40 AM UTC
The links do not actually provide documentation on the APIs presented by X-CUBE-CRYPTOLIB. As an example, I'd like to use CMOX to implement AES128-CTR, but I cannot find documentation on which part of the IV is used as the nonce, and which part is used as the counter. The wiki mentions a cmox.chm file which does not exist in the 4.1.0 release of the library.
Where can I find a more complete set of documentation for the new X-CUBE-CRYPTOLIB API?
Aug 10, 2023 2:11 AM UTC
Most typically with AES128-CTR implementations the IV is left aligned, with the slack portion on the right being zero filled, and the whole word increments, from the right side.
There have definitely been multiple requests to get better / complete documentation.
