Sep 25, 2024 6:43 AM UTC
X-CUBE-CRYPTOLIB problem
Hello, I have created an encrypted file by openssl-aes256-CFB. in openssl IV length should be 128 bit but in X-CUBE-CRYPTOLIB it is not possible,  it cannot set to 128 bit, (HARDFAULT). only i can set 256bit and then received error 0x10003
Oct 29, 2024 12:48 AM UTC
Hello @nima.askari, I'm checking with team.
Best Regards,
Younes
Oct 30, 2024 8:18 AM UTC
IV shall be 128 bits (size of an AES block).
If hardfault occurs, then may be be there is an issue in your code/project as the CFB have been deeply tested… !!
Can you share the code + openssl used commands ?
Best Regards
