SPati.7
Apr 14, 2022 9:36 AM UTC
what is the FIPS certification available for X-CUBE-CRYPTOLIB ?? I see NIST-CAVP Certification which is FIPS 186, what is the difference from FIPS 140-2/140-3 complaint. is both are same ?
We are looking for FIPS 140-2 / 140-3 certified Secure Boot loader implemented with help of X-CUBE-CRYPT LIB for STM32H753VI MCU.
if i see NIST-CAVP certification, it is mentioned as STM32L4 series, then is thios same certificate is applicable for STM32H7 ?? if not is STM will help us to get FIPS certification for STM32H7 series as well ..??
Please share the details as much as possible on this.
@Jocelyn RICARD​  can you help with this FIPS or can you redirect to someone who handles FIPS certification.
Jocelyn RICARD
Apr 14, 2022 12:02 PM UTC
Hello @SPati.7​ ,
Please check our wiki page related to our X-CUBE-CRYPTOLIB about validation through NIST CAVP here
This concerns the cryptolib V4.
In this version, the library is associated to each Cortex-M and not to specific STM32.
For old version 3.1, only L4 went through this functional validation. But exact same code was used to compile on other chips.
The CAVP allows you to reach certify your product with FIPS 140-2 certification level 1 and level 2
Best regards
Jocelyn
SPati.7
SPati.7Author
Apr 14, 2022 12:48 PM UTC
@Jocelyn RICARD​  We are not sure as of now, whether CAVP certification will suffice to get FIPS 140-2.
We don't have enough expertise to confirm this, and we are looking now.
So from V4, we have NIST-CAVP certification for Cortex M7 as well. is this current CRYPTO library version ??
SPati.7
SPati.7Author
Apr 14, 2022 2:47 PM UTC
@Jocelyn RICARD​  Where does Option Bytes stored which is persistent across power cycles ?? is it inside System Flash or User Flash ??
Trying to understand RD LVL 2 protection, how it works and at what stage it apply ??
Can you help with these details ??
Fred
Apr 15, 2022 1:23 PM UTC
there is this document providing maybe more details:
https://www.st.com/content/ccc/resource/sales_and_marketing/presentation/product_presentation/group0/79/b4/63/20/21/53/47/54/fips_cavp_certification/files/fips_cavp_certification.pdf/jcr:content/translations/en.fips_cavp_certification.pdf
But I will also ask some colleagues.
Regarding RDP Level 2, please be careful with this because once you configure the product in RDP level 2 then it is locked and you cannot go back to another (more permissive) RDP Level. This means that your product is "frozen" unless the firmware you have already programmed in it allows you to do firmware update.
Fred
Apr 19, 2022 9:43 AM UTC
I think you can use the validation number from the link I indicated in the previous post with this web site:
https://csrc.nist.gov/projects/cryptographic-algorithm-validation-program/validation-search?searchMode=validation&validationNumber=3971&productType=-1&ipp=25
Then you get this kind of information:
https://csrc.nist.gov/projects/cryptographic-algorithm-validation-program/details?product=5441
This is for X-CUBE-CRYPTOLIB so V3.
With V4, the latest information is here:
https://wiki.st.com/stm32mcu/wiki/Security:Cryptographic_Library_Certifications
