STSAFE-A110 SPL02 – Global Usage Limit, Signature Operations, and Counter Behavior
Hello ST Community,
We are currently evaluating the STSAFE-A110 with the SPL02 profile (STSAFA110S8SPL02) and have a few technical questions regarding the global usage limit and its behavior.
While reviewing the available documentation, we could not find definitive information about the following points:
Factory configuration: What is the factory-configured global usage limit for the SPL02 profile?
Unlimited usage: Does
0xFFFFalso represent unlimited usage for the global limit, as it does for individual key slots? -
Counter consumption: Which operations consume the global usage limit? Specifically, does every
Generate Signatureoperation decrement this counter? -
Configurability: Is the global usage limit configurable after manufacturing, or is it permanently defined by the factory profile?
Counter readout: Does
stse_get_ecc_key_table_info()return the originally configured global usage limit or the remaining usage count?
We initially contacted STMicroelectronics Support and were directed to this community forum for further technical clarification.
If there is any application note, technical specification, or other documentation covering these details, a reference would also be greatly appreciated.
Thank you in advance for your assistance.
