FYASA.1
Apr 26, 2021 1:14 AM UTC
STM32WL55 SBSFU is not compiling on MacOS
I am working on a project using STM32Cube_FW_WL_V1.0.0.
I cannot compile the 1_Image_SECoreBin project included in the BFU_1_Image sample project.
I am using STM32CubeIde on macOS Catalina.
I have also read these manuals.
"Getting started with the SBSFU of STM32CubeWL"
"Integration guide of SBSFU on STM32CubeWL (including KMS)"
Can you guys guide me?
Jocelyn RICARD
Jocelyn RICARDBest answer
May 4, 2021 5:55 PM UTC
About bash option in Catalina this is quite strange as bash is supposed to be standard. I can't tell ...
About Win10 issue, this is a know issue related to latest STM32CubeIDE.
You can find the way to fix it in https://community.st.com/s/question/0D53W00000cRsLASA0/the-update-to-cubeide-160-cause-a-linker-error-compiling-the-userapp
Best regards
Jocelyn
FYASA.1
FYASA.1Author
Apr 26, 2021 10:26 PM UTC
Hi there,
I also tried on Windows 10.
I installed necessary tool chain for STM32CubeMXIde.
Then I prepared SBSFU_2_Images_DualCore sample project
I'm sure that, compiling the correct order according to Getting started with the SBSFU of STM32CubeWL (UM2767)
Compile order is;
  • 2_Images_SECoreBin - compile success
  • 2_Images_KMS_Blob - compile success
  • 2_Images_SBSFU
    • 2_Images_SBSFU_CM0PLUS - compile success
    • 2_Images_SBSFU_CM4) - compile success
  • 2_Images_UserApp_CM4 - compile success
  • 2_Images_UserApp_CM0PLUS - compiler error
The error is multiple definition error .
c:\st\stm32cubeide_1.6.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.win32_1.5.0.202011040924\tools\arm-none-eabi\bin\ld.exe: ../../../2_Images_SBSFU/STM32CubeIDE/CM0PLUS/Debug\se_interface_app.o: in function `SE_KMS_CloseSession':
(.SE_IF_Code+0xbd8): multiple definition of `SE_KMS_CloseSession'; ../../../2_Images_SBSFU/STM32CubeIDE/CM0PLUS/Debug\se_interface_app.o:(.SE_IF_Code+0xbd8): first defined here
c:\st\stm32cubeide_1.6.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.win32_1.5.0.202011040924\tools\arm-none-eabi\bin\ld.exe: ../../../2_Images_SBSFU/STM32CubeIDE/CM0PLUS/Debug\se_interface_app.o: in function `SE_KMS_DigestInit':
(.SE_IF_Code+0x121c): multiple definition of `SE_KMS_DigestInit'; ../../../2_Images_SBSFU/STM32CubeIDE/CM0PLUS/Debug\se_interface_app.o:(.SE_IF_Code+0x121c): first defined here
c:\st\stm32cubeide_1.6.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.win32_1.5.0.202011040924\tools\arm-none-eabi\bin\ld.exe: ../../../2_Images_SBSFU/STM32CubeIDE/CM0PLUS/Debug\se_interface_app.o: in function `SE_KMS_EncryptInit':
(.SE_IF_Code+0xedc): multiple definition of `SE_KMS_EncryptInit'; ../../../2_Images_SBSFU/STM32CubeIDE/CM0PLUS/Debug\se_interface_app.o:(.SE_IF_Code+0xedc): first defined here
c:\st\stm32cubeide_1.6.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.win32_1.5.0.202011040924\tools\arm-none-eabi\bin\ld.exe: ../../../2_Images_SBSFU/STM32CubeIDE/CM0PLUS/Debug\se_interface_app.o: in function `SE_KMS_DestroyObject':
(.SE_IF_Code+0xc94): multiple definition of `SE_KMS_DestroyObject'; ../../../2_Images_SBSFU/STM32CubeIDE/CM0PLUS/Debug\se_interface_app.o:(.SE_IF_Code+0xc94): first defined here
c:\st\stm32cubeide_1.6.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.win32_1.5.0.202011040924\tools\arm-none-eabi\bin\ld.exe: ../../../2_Images_SBSFU/STM32CubeIDE/CM0PLUS/Debug\se_interface_app.o: in function `SE_KMS_Encrypt':
(.SE_IF_Code+0xf3c): multiple definition of `SE_KMS_Encrypt'; ../../../2_Images_SBSFU/STM32CubeIDE/CM0PLUS/Debug\se_interface_app.o:(.SE_IF_Code+0xf3c): first defined here
I didn't do any code change, I just downloaded and opened in STM32CubeIde.
Is this related with STM32Cube_FW_WL_V1.0.0 ?
What's wrong ?
Thank you
Jocelyn RICARD
Best regards
Jocelyn
FYASA.1
FYASA.1Author
May 8, 2021 8:21 PM UTC
Thank you Jocelyn,
The problem was caused by the macos. Catalina version uses default zsh instead of bash.
As a solution for those who encounter a similar problem: https://www.howtogeek.com/444596/how-to-change-the-default-shell-to-bash-in-macos-catalina/
