STM32WL Security
Do all the STM32WL series MCUs support STSAFE ? If yes, how it can be done?
Hi @mathi_manoj ,
The STSAFE-A is a companion chip with I2C link, therefore is any MCu with I2C can use STSAFE-A.
You can check the STSELib which is the command wrapper and propose some code examples to run the STSAFE-A120 scenarios.
You need to check the PAL part for the implementation details on STM32.
Best Regards,
Benjamin
Thank you
