STM32WBA65 – RDP level 2 regression with OEM2 password reports success but the device stays locked (NUCLEO-WBA65RI, OEMiRoT)
Setup
- Board: NUCLEO-WBA65RI (STM32WBA65, Device ID 0x4B0, Rev Z), on-board ST-LINK V3, SN 0032001C3234510536303532, firmware V3J16M9B5S1
- STM32CubeProgrammer 2.21.0 (macOS CLI; the Windows GUI was also tried, see below)
- Firmware: the OEMiRoT example from STM32CubeWBA 1.9.0 (
Projects/STM32WBA65I-DK1/Applications/ROT): OEMiROT_Boot with OEMIROT_DEV_MODE, plus OEMiROT_Appli_TrustZone. Provisioned withROT_Provisioning/OEMiROT/provisioning.sh, RDP level 0 selected. - Option bytes before the incident (read with
-ob displ): RDP 0xAA, TZEN 1, BOOT_LOCK 1, SECBOOTADD0 → 0x0C006000, SECWM1 sectors 0x0–0xF, WRP1A sectors 0x2–0xB, HDP1EN 1 with HDP1_PEND 0xA. - OEM2 key: programmed by provisioning.sh at RDP 0 with
-c port=SWD mode=UR -hardRst -lockRDP2 0xFACEB00C 0xDEADDEAD(the example key fromKeys/oem2_password.txt). The log reports "Lock RDP2 password successfully done". Afterwards FLASH_NSSR (0x40022020) read 0x00080000, so OEM2LOCK = 1. OEM1 was not provisioned (OEM1LOCK = 0).
What happened
With RDP 0 and full debug access, we ran
-c port=SWD mode=HOTPLUG -ob RDP=0xCCto test the RDP 2 lock and regression. The output showed "Unable to get core ID" and "Option Bytes Programming is not supported for Device: 0x0000", meaning the connection failed before any programming. From then on, the debugger can no longer reach the core. We can't tell from our logs exactly when RDP 2 took effect. -
In every connection mode (HOTPLUG, UR, NORMAL, POWERDOWN) and at SWD speeds of 8 MHz, 1 MHz and 100 kHz, the result is the same: Device ID 0x4B0 is read, then "Unable to get core ID" or "Cannot connect to access port 1".
-ob displis not possible. -
The device is not dead. On a scope, NRST is a normal 3.2 V and goes low only while the reset button is held. After reset, USART1 TX (PB12) sends the complete OEMiRoT boot log at 115200 baud: image validation passes and it jumps to the application, which prints its menu. So OEMiRoT and the non-secure application run normally after reset.
RDP 2 regression attempts:
-c port=SWD mode=UR -hardRst -unlockRDP2 0xFACEB00C 0xDEADDEAD, also throughROT_Provisioning/OEMiROT/regression.sh-c port=SWD mode=HOTPLUG [freq=1000] -unlockRDP2 0xFACEB00C 0xDEADDEAD
Each attempt prints two
libusb: warning [darwin_transfer_status] transfer error: timed outlines, then "INIT AP OK!" with-vb 3, then "Unlock RDP2 password successfully done". The automatic target power-on then fails ("Failed to Power ON the board"). After a full power-on reset (USB unplugged for 10 s, no other supply), the device is still not accessible, in HOTPLUG mode included, while the non-secure application is running. -
Windows GUI (CubeProgrammer 2.21.0): the OEM2 panel shows two key fields and an "OEM2 lock mechanism is …" status line. Entering
0xFACEB00C/0xDEADDEADgave an "invalid address" warning. [Confirm: what the status line said, and that no Lock button was pressed.]
Questions
- On STM32WBA65, is there a known condition where
-unlockRDP2reports success but the RDP 2 → 1 regression does not take effect? For example, a required reset type, the access port used, or behaviour that depends on TZEN or BOOT_LOCK. - Is there a way to read the current RDP level or OEM2 lock state through the debug access port while the core AP is closed?
- What is the correct procedure for this regression on a NUCLEO-WBA65RI? Is a newer CubeProgrammer or ST-LINK firmware required?
- With OEM1 not provisioned and BOOT_LOCK = 1, is there any recovery route other than the OEM2 regression?
