Mar 20, 2025 10:07 AM UTC
STM32U5 - SBSFU
Good Morning,
I am working on the Secure Boot using STM32U5 with this repository : https://github.com/STMicroelectronics/STM32CubeU5/tree/main/Projects/B-U585I-IOT02A/Applications/SBSFU
I am trying to add a kind of "Dev. Mode" which authorise the boot even if the Application's flash is corrupted.
Are there any restriction from the SBSFU_Boot code or ROM code that prevents this feature ?
Moreover, do you have any links to the SBSFU_Boot.bin sources, especially the main.c or this part is private and can't be shared ?
Best Regards,
Loïc
Jocelyn RICARD
Jocelyn RICARDBest answer
Mar 20, 2025 1:46 PM UTC
Hello @lotou ,
You have access the the whole source code.
You can find the main in bl2_main.c located in mcuboot in Middlewares
There is no restriction, just a matter of changing the code to allow such behaviour
Best regards
Jocelyn
Jocelyn RICARD
Hello @lotou ,
Best regards
Jocelyn
