Aug 5, 2026 16:29 UTC
STM32H573 Secure Manager: PSA Crypto Issues with TLS 1.3
Hello everyone,
I am trying to use TLS 1.3 with Mbed TLS on an STM32H573 through the Secure Manager’s Global PSA API.
At the moment, I am seeing the following errors:
psa_sign_hash() / psa_sign_message()
→ PSA_ERROR_NOT_PERMITTED
psa_generate_key() / psa_import_key()
→ PSA_ERROR_GENERIC_ERROR
The persistent ECC keys are provisioned with the required signing permissions, and both the Secure Manager and the non-secure application start correctly.
Some TLS 1.3 HKDF operations had to be implemented locally because the PSA Crypto API version in use is 1.0 and does not provide separate HKDF-Extract and HKDF-Expand algorithms.
My questions are:
  • Are persistent ECC keys supported with psa_sign_hash() through the Global PSA API?
  • Does the Secure Manager support volatile keys with psa_generate_key() and psa_import_key()?
  • Are additional permissions or a Secure Module required?
  • Is there a support matrix or an official TLS 1.3 example for this setup?
  • Does anyone have experience with Secure Manager and MbedTLS 1.3, or with configuring Secure Manager for TLS 1.3?
Thank you!
Jocelyn RICARD
Jocelyn RICARDBest answer
Aug 14, 2026 17:52 UTC
Hello ​@MarioM ,
I attach the workaround you can use for TLS 1.3
Otherwise, Secure Manager should support all what you need.
Best regards
Jocelyn
Jocelyn RICARD
Hello ​@MarioM ,
Best regards
Jocelyn
MarioMAuthor
Aug 17, 2026 14:45 UTC
Hi ​@Jocelyn RICARD,
it's working perfectly now. Thank you very much!
Best regards
Mario
