Vinay_Shirol
Mar 5, 2026 9:20 AM UTC
STM32CubeExpansion_SBSFU_V2.8.0 (2_Images_SECoreBin) fails with GNU14.3 Toolchain from CubeIDE
Hi ST team,
I am using X-CUBE-SBSFU V2.8.0, project:
  • Device: STM32H753
  • Base example: NUCLEO-H753ZI 2_Images
  • I ported UART pins/port for my H753 EVAL board.
Problem
  • Build fails in SECoreBin with GNU14.3 toolchain:
  • C:/.../2_Images_SECoreBin/Src/se_crypto_bootloader.c:222:(.text.SE_CRYPTO_Decrypt_Init+0x16): dangerous relocation: unsupported relocation
However , Then i shifted to 13.3 tool chain , then everything works fine for me.
Please confirm whether this is a known GCC 14.3 compatibility issue for SBSFU v2.8.0 key generation. If yes, could you share an official patch for prebuild.sh / key assembly generation so generated key symbols are fully compatible with newer GNU/binutils?
Jocelyn RICARD
Jocelyn RICARDBest answer
Mar 9, 2026 10:57 PM UTC
Hello @Vinay_Shirol ,
I can reproduce your issue with latest STM32CubeIDE 2.1.0 pulling GCC 14.3
I could find a temporary workaround:
1) disable the prebuild adding a # in front of the prebuild.sh in build steps
2) Edit se_keys.s
Replace
.section .SE_Key_Data,"a",%progbits
by
.section .SE_Key_Data,"ax",%progbits
replace
	.global SE_ReadKey_1
SE_ReadKey_1:
by
	.thumb_func
SE_ReadKey_1:
and same for SE_ReadKey_1_Pub:
As least link is ok. But didn't check more
Best would be to fix prepareimage.py
Will ask for this fix.
Best regards
Jocelyn
Jocelyn RICARD
2) Edit se_keys.s
Replace
by
replace
SE_ReadKey_1:
by
	.thumb_func
SE_ReadKey_1:
Best regards
Jocelyn
Vinay_Shirol
Mar 11, 2026 4:11 AM UTC
Thanks @Jocelyn RICARD ,
                                    I will try these changes and update here.
