STM32 cryptographic firmware ECDSA
Hi ST,
     What tool generated the following data?Can you send me this tool? thanks.
https://www.st.com/en/embedded-software/x-cube-cryptolib.html
STM32 cryptographic firmware library software expansion for STM32Cube.
The path of the code is as follows:
.\STM32CubeExpansion_Crypto_V4.2.0\Projects\NUCLEO-G474RE\Applications\ECC\ECDSA_SignVerify\Src\main.c
Tesla DeLoreanBest answer
July 26, 2024
https://csrc.nist.gov/projects/cryptographic-algorithm-validation-program/digital-signatures
https://csrc.nist.gov/CSRC/media/Projects/Cryptographic-Algorithm-Validation-Program/documents/dss2/ecdsa2vs.pdf
https://csrc.nist.gov/CSRC/media/Projects/Cryptographic-Algorithm-Validation-Program/documents/dss/186-4ecdsatestvectors.zip (SigGen.txt this vector about 10% into file, grep or search for it)
If you want to replicate, convert the message into a byte array, run SHA-224, check d
Use your signing code, the private key and the random data to recreate the signing, and then verify
Make a "pretty printer" to output info in this format for your own keys or whatever.
This is really just a validation pattern people can use to assure the algo is implemented and working correctly.
Joe WILLIAMS
Hi Roger0x0000
This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
Kind Regards
Joe
STMicro Support
July 26, 2024
Looks to be cut from the NIST test vectors. For some of the newer ones they had .PY scripts too.
But you could test and make your own with things like Micro ECC and there are other Windows tools
July 26, 2024
