leeana
Oct 4, 2021 7:13 AM UTC
Sharing UART between SBSFU and user app
Hello
I would like to use the same UART that is used in SBSFU, to communicate with the host PC for service purposes. Is it possible? Maybe create kind of a wrapper interface like "press 1 for sbsfu, 2 for logs"? A little bit confused how to implement it if possible. It is the only UART available on my custom board, all pins are already used.
Jocelyn RICARD
Jocelyn RICARDBest answer
Oct 4, 2021 12:00 PM UTC
Hello @leeana​
there no problem sharing the link between SBSFU and application. As soon as SBSFU jumps to application you have access to all resources.
Best regards
Jocelyn
Jocelyn RICARD
Hello @leeana​
Best regards
Jocelyn
leeana
leeanaAuthor
Oct 4, 2021 3:48 PM UTC
thank you, Jocelyn! After re-reading the docs for a fourth time I've finally got how it works.
