coffeeMaker
Oct 27, 2020 2:28 PM UTC
Set RDP LEVEL without st link utility?
I would like to set the RDP LEVEL for my stm32l0 MCU without using ST link utility software,
to be more specific, how I can set the level in the firmware to be flashed in which area ? and is it possible to add a script to linker to set the RDP level without changing the code?
Please advice.
Thanks.
Tesla DeLoreanBest answer
Oct 27, 2020 3:23 PM UTC
Your own code can write the options bytes any way it wants. You can have it self initiate a change based on desired vs current settings, or from your own user/command interface to your product..
coffeeMaker
Oct 27, 2020 3:42 PM UTC
thanks @Community member​
coffeeMaker
Oct 30, 2020 8:14 AM UTC
hello again,
Just following same context which is RDP, I was able to change the RDP for my MCU by Firmware, but the problem is I need to do the Power on cycle after flashing the FW so the Option bytes change, the NVIC_SystemReset() seems not working at all, my question is if my final device is battery based how I can do a POC to make sure the RDP level has been changed after first flash?
