Sep 4, 2025 11:02 AM UTC
Secure Boot Implementation
Hi
I am trying to perform a secure boot implementation in STM32F439ZIT6. The datasheet shows that, there is Hash, RNG, AECS and TDES. Can I perform secure boot functionality using only STM32F439ZIT6 without using any external chip and if so, are there any library files which contain functions to perform this secure boot operation and is there any application notes, example codes or videos I can refer to perform this functionality?
Thanks and Regards
@avbST
Sep 5, 2025 9:39 AM UTC
Hello @avbST,
I recommend checking out this article: Introduction to Secure boot and Secure firmware update
Additionally, I suggest reading this post: How to implement secure boot on STM32 MCU
Both will assist you in understanding Secure Boot and its implementation.
I hope my answer has helped you. When your question is answered, please select this topic as the solution that answered you, as it will help others find that answer faster.
Thanks for your contribution.
Dor_RH
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Dor_RH
