SBSFU | KMS | How to use KMS_GenerateKeyPair()
Hello all.
I have a question about how to use KMS_GenerateKeyPair() function. There are no examples in the code, and API description is not really enough for my little brain. Could somebody provide me an example on how it should be used? What kind of parameters, how to initialize them and so on. I would be grateful!
Jocelyn RICARD
Jocelyn RICARDBest answer
Hello @Jakub Standarski ,
KMS is implementing PKCS#11 standard.
So, you should find an example somewhere.
Using google I found a video and example in associated gihub here
Best regards
Jocelyn
Jocelyn RICARD
Best regards
Jocelyn
Much appreciated! That's what I needed.
Jocelyn RICARD
first regarding debugging capability, you must change optimization level at least for the files that are involved.
About your issue, I could find something in the code in file
Projects\B-L4S5I-IOT01A\Applications\2_Images_KMS\2_Images_SBSFU\SBSFU\App\sfu_scheme_x509_mbedtls_ecdsa_verify.c
 else if(p_grp->id == MBEDTLS_ECP_DP_SECP384R1)
 ref_secp[0] = 0x81;
 ref_secp[1] = 0x2b;
 ref_secp[2] = 0x05;
 ref_secp[3] = 0x06;
 ref_secp[4] = 0x22;
 ref_secp[5] = 0x00;
 ref_secp[6] = 0x04;
So, it looks like buffer needs to be adapted to little endian.
Best regards
Jocelyn
Regarding debugging capabilities - yes, I'm aware of a need to change optimization level, the thing is that we don't have enough space so I had to operate on what was currently available.
Regarding the main issue though, that looks like potential solution (I will give it a try soon). I've been wondering why is that, because I've seen same numbers but in different order while debugging. On the other hand I took example from pkcs11 tutorial and was a bit confused. Thanks for clarification!
