ANaga.2
Sep 1, 2020 6:55 AM UTC
SBSFU : how to remove write protection?
I forgot to comment the protections set in app_sfu.h and tried debugging the code.
Later I realized and commented everything and it is not allowing me to flash the program on the device.
I made RDP level 0 from cube programmer, but still write protection is enabled which is not allowing me to format the device.
Could anyone please let me know how can i remove write protections in cube programmer.
Thanks,
Ankush
Nesrine.JLASSI
Nesrine.JLASSIBest answer
Sep 1, 2020 9:12 AM UTC
Hi @ANaga.2​
Please try this command" -c port=swd -ob displ "then tell me the output to check the issue.
C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer-2.5.0\bin>STM32_Programmer_CLI.exe -c port=swd -ob displ
            STM32CubeProgrammer v2.5.0
ST-LINK SN : 0669FF303435554157042733
ST-LINK FW : V2J30M19
Board    : NUCLEO-L476RG
Voltage   : 3.26V
SWD freq  : 4000 KHz
Connect mode: Normal
Reset mode : Software reset
Device ID  : 0x415
Revision ID : Rev 4
Device name : STM32L4x1/STM32L475xx/STM32L476xx/STM32L486xx
Flash size : 1 MBytes
Device type : MCU
Device CPU : Cortex-M4
UPLOADING OPTION BYTES DATA ...
 Bank     : 0x00
 Address    : 0x40022020
██████████████████████████████████████████████████ 100%
 Bank     : 0x01
 Address    : 0x40022044
OPTION BYTES BANK: 0
  Read Out Protection:
   RDP     : 0xAA (Level 0, no protection)
  BOR Level:
   BOR_LEV   : 0x0 (BOR Level 0, reset level threshold is around 1.7 V)
  User Configuration:
   nRST_STOP  : 0x1 (No reset generated when entering Stop mode)
   nRST_STDBY  : 0x1 (No reset generated when entering Standby mode)
   nRST_SHDW  : 0x1 (No reset generated when entering the Shutdown mode)
   IWDG_SW   : 0x1 (Software independant watchdog)
   IWDG_STOP  : 0x1 (IWDG counter active in stop mode)
   IWDG_STDBY  : 0x1 (IWDG counter active in standby mode)
   WWDG_SW   : 0x1 (Software window watchdog)
   BFB2     : 0x0 (Dual-bank boot disable)
   nBOOT1    : 0x1 (Boot from Flash if BOOT0 = 0, otherwise system memory)
   SRAM2_PE   : 0x1 (SRAM2 parity check disable)
   SRAM2_RST  : 0x1 (SRAM2 is not erased when a system reset occurs)
  PCROP Protection (Bank 1):
   PCROP1_STRT : 0xFFFF (0x807FFF8)
   PCROP1_END  : 0x0 (0x8000000)
   PCROP_RDP  : 0x0 (PCROP zone is kept when RDP is decreased)
  Write Protection (Bank 1):
   WRP1A_STRT  : 0xFF (0x807F800)
   WRP1A_END  : 0x0 (0x8000000)
   WRP1B_STRT  : 0xFF (0x807F800)
   WRP1B_END  : 0x0 (0x8000000)
OPTION BYTES BANK: 1
  PCROP Protection (Bank 2):
   PCROP2_STRT : 0xFFFF (0x80FFFF8)
   PCROP2_END  : 0x0 (0x8080000)
  Write Protection (Bank 2):
   WRP2A_STRT  : 0xFF (0x80FF800)
   WRP2A_END  : 0x0 (0x8080000)
   WRP2B_STRT  : 0xFF (0x80FF800)
   WRP2B_END  : 0x0 (0x8080000)
Best regards,
Nesrine
Nesrine.JLASSI
Sep 1, 2020 8:58 AM UTC
Hello @ANaga.2​ ,
Could you please give me more details about the Board name used .
Best regards,
Nesrine
ANaga.2
ANaga.2Author
Sep 1, 2020 8:59 AM UTC
Its L476RG
Nesrine.JLASSI
Hi @ANaga.2​
Voltage   : 3.26V
SWD freq  : 4000 KHz
Device ID  : 0x415
Revision ID : Rev 4
Device type : MCU
 Bank     : 0x00
 Bank     : 0x01
  BOR Level:
  User Configuration:
Best regards,
Nesrine
ANaga.2
ANaga.2Author
Sep 2, 2020 11:56 AM UTC
It worked. Thank you so much
jarus0
Dec 22, 2022 10:05 AM UTC
Hello everyone, We were testing out the SBSFU example for our 2 running projects.
But currently, we are unable to upload any other program to the device.
Here is the STM32CubeProgrammer log for "Full chip erase" request
 15:26:43:686 : MASS ERASE ...
 15:26:43:693 : Flash erase...
 15:26:43:694 : halt ap 0
 15:26:43:716 : Init flashloader...
 15:26:43:716 : halt ap 0
 15:26:43:718 : run ap 0
 15:26:43:735 : halt ap 0
 15:26:43:735 : Loader mass erase...
 15:26:43:737 : run ap 0
 15:26:43:737 : halt ap 0
 15:26:43:737 : Error: Mass erase operation failed.Please verify flash protection
And below CLI output is given
Please have a look and suggest us to resolve this.
./STM32_Programmer_CLI -c port=swd -ob displ
 STM32CubeProgrammer v2.12.0
ST-LINK SN : 0671FF313736504157192620
ST-LINK FW : V2J40M27
Board : NUCLEO-G070RB
Voltage : 3.23V
SWD freq : 4000 KHz
Device ID : 0x460
Revision ID : Rev B
Device name : STM32G07x/STM32G08x
Flash size : 128 KBytes
Device type : MCU
Device CPU : Cortex-M0+
BL Version : 0xB2
Debug in Low Power mode enabled
 Bank : 0x00
[==================================================] 100%
 BOR Level:
 BOR_EN : 0x0 (Configurable brown out reset disabled, power-on reset defined by POR/PDR levels)
 BORR_LEV : 0x0 (BOR rising level 1 with threshold around 2.1 V)
 BORF_LEV : 0x0 (BOR falling level 1 with threshold around 2.0 V)
 User Configuration:
 RAM_PARITY_CHECK: 0x1 (SRAM parity check disable)
 nBOOT_SEL : 0x1 (BOOT0 signal is defined by nBOOT0 option bit)
 nBOOT0 : 0x1 (nBOOT0=1)
 NRST_MODE : 0x3 (Bidirectional reset: NRST pin configured in reset input/output mode (legacy mode))
 IRHEN : 0x1 (Internal resets drives NRST pin low until it is seen as low level)
 PCROP Protection:
 PCROP1A_STRT : 0xFF (0x801FE00)
 PCROP1A_END : 0x0 (0x8000200)
 PCROP1B_STRT : 0xFF (0x801FE00)
 PCROP1B_END : 0x0 (0x8000200)
 Write Protection:
 WRP1A_STRT : 0x0 (0x8000000)
 WRP1A_END : 0x1F (0x800F800)
 WRP1B_STRT : 0x3F (0x801F800)
 FLASH security:
 BOOT_LOCK : 0x0 (Boot based on the pad/option bit configuration)
 SEC_SIZE : 0x20 (0x8010000)
