Jun 9, 2026 09:23 UTC
SBSFU Functional Modifications and Swap Area Relocation for STM32H743ZIT6
I am currently working with SBSFU on the STM32H743ZIT6 series and have implemented several modifications to its core functionality. I would like to clarify the potential impact of these changes.
1. Modification to SBSFU Functionality
I have altered the default SBSFU behavior by replacing the traditional firmware swapping mechanism with a bank-switching approach to reduce application downtime.
  • Both Bank 1 and Bank 2 will contain the bootloader and the application.
  • Bank selection is managed using the swap option byte.
2. Relocation of Swap Area
I plan to relocate the swap area from Sector 8 to Sector 15, considering that Bank 2 spans from Sector 0 to Sector 7.
  • The swap area is used during the decryption process.
  • It requires 128 KB of memory.
3. Clarification Required
I would like to understand whether these modifications will have any impact on the system:
  • Will the transition from a swap-based mechanism to a bank-switching approach affect the core functionality, integrity, or reliability of SBSFU?
  • Does relocating the swap area to a different sector introduce any functional or design constraints?
  • Is it recommended to use a different sector for the decryption (swap) area?
Thankyou in Advance
Billy OWEN
Jun 12, 2026 19:47 UTC
Hi ​@vasanthKumar
This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
Regards,
Billy
Jun 15, 2026 09:19 UTC
Hi ​@Billy OWEN,
Thanks for your reply. Any updates on my queries?
Regards,
vasanthKumar
