Nov 5, 2025 13:53 UTC
SBSFU_Boot on STM32U5A9
I am working with the SBSFU_Boot on the STM32U5A9 chip. After the SBSFU_Loader has written the update image into internal memory, a reset happens in order for the SBSFU_Boot to write the image to be booted. When performing the update, it ends up in a process where it has to do some encryption. The SAES engine is initialized successfully, and then AES_Encrypt is called. This keeps on failing because a read error is reported in the SAES->SR reports a read error upon enabling the SAES peripheral.
It should be noted that the initialization and encryption sequence is strictly followed per instructions in RM0456 Rev 6 sections 50.4.4 (Initialization of SAES) and 50.4.8 (ECB/CBC encryption sequence) respectively.
What am I missing?
MouriceBest answer
Apr 23, 2026 06:23 UTC
Hi Jocelyn,
It turns out that the SAES wasn't configured correctly. After this was sorted out, it worked.
Best regards,
Mourice.
Jocelyn RICARD
Nov 11, 2025 14:51 UTC
Hello @Mourice ,
From your description it is not clear if you have made adaptations or not.
Could you please provide more details?
Best regards
Jocelyn
MouriceAuthor
Nov 12, 2025 09:16 UTC
Hi Jocelyn,
I have not made any adaptations.
Best regards,
Mourice.
Jocelyn RICARD
Nov 13, 2025 19:28 UTC
Hello @Mourice ,
OK thank you. I will try to reproduce the issue.
Best regards
Jocelyn
MouriceAuthor
Nov 17, 2025 12:59 UTC
Hi @Jocelyn RICARD ,
I am looking forward to your findings.
Best regards,
Mourice.
Jocelyn RICARD
Nov 28, 2025 16:16 UTC
Hello @Mourice,
I couldn't reproduce your issue.
I used latest STM32Cube_FW_U5_V1.8.0 as base and followed readme to adapt B-U585I-IOT02A to STM32U5A9J-DK.
It is booting properly and update is working as expected.
I join the adaptation I made so that you can check on your side.
Best regards
Jocelyn
MouriceAuthor
Dec 4, 2025 12:43 UTC
Hi Jocelyn,
I will try out your adaptation and give you feedback.
Best regards,
Mourice.
MouriceAuthorBest answer
Hi Jocelyn,
Best regards,
Mourice.
