zqizh.1
Nov 23, 2021 6:02 AM UTC
"regression.sh" in "STM32Cube_FW_L5_V1.4.0" can't execute successfully
I don't do any change to the script file, please advise how to let the script work normally.
Rgds,
QiZhang
D:\>cd D:\WSL_DIR\STM32Cube_FW_L5_V1.4.0\Projects\STM32L562E-DK\Applications\TFM\TFM_SBSFU_Boot\STM32CubeIDE
D:\WSL_DIR\STM32Cube_FW_L5_V1.4.0\Projects\STM32L562E-DK\Applications\TFM\TFM_SBSFU_Boot\STM32CubeIDE>bash regression.sh
regression script started
Regression to RDP 0, enable tz
regression.sh: line 16: $'STM32_Programmer_CLI\r': command not found
regression.sh: line 59: syntax error: unexpected end of file
Pavel A.
Pavel A.Best answer
Nov 26, 2021 10:28 PM UTC
> my PC OS is win 10 , with WSL2 installed
So, when you type 'bash' it actually runs in the WSL. It does not run on the Windows side. Do you fully understand the consequences?
Maybe you would rather prefer a Windows-native bash such as one that comes with git or Cygwin?
Nov 26, 2021 5:27 AM UTC
Hello @zqizh.1​ ,
I have checked from my side and I cannot reproduce this issue.
Were you able to resolve this ? If yes, it will be interesting to share with us your update.
Imen
zqizh.1
zqizh.1Author
Nov 26, 2021 9:21 AM UTC
I have solved it with below work around solution:
1) change "STM32_Programmer_CLI" to"STM32_Programmer_CLI.exe" in line 4
2) remove "\r"
sed 's/\r$//' regression.sh > tmp.sh
mv tmp.sh regression.sh
my PC OS is win 10 , with WSL2 installed.
Please give a formal way.
Rgds,
QiZhang
Pavel A.
Pavel A.Best answer
zqizh.1
zqizh.1Author
Nov 29, 2021 1:53 AM UTC
I've followed your instruction, uninstall the WSL2, and install the Cygwin.
$ cd /cygdrive/d/WSL_DIR/STM32Cube_FW_L5_V1.4.0/Projects/STM32L562E-DK/Applications/TFM/TFM_SBSFU_Boot/STM32CubeIDE/
1) run "./regression.sh" no problem.
2) run "./TFM_UPDATE.sh" fail.
Please advise.
Thanks.
