leeana
Oct 5, 2021 7:58 AM UTC
Problems building SECoreBin (prebuild.sh)
Hello everyone,
I am trying to build SECoreBin, but the build fails with prebuild.sh. All python requirements listed in requirements.txt are installed, but the error is following:
ImportError: No module named Cryptodome.Cipher
And even more:
What should I do? As I have said, cryptodome is installed.
leeana
leeanaBest answer
Oct 5, 2021 8:58 AM UTC
Thank you, Jocelyn. I've checked the version and these were different (python3 required, but python2 was called). I have changed the default python version to 3.8 and it worked. (I am working under ubuntu).
Jocelyn RICARD
Oct 5, 2021 8:41 AM UTC
Hello @leeana​
Which platform are you using ?
Can you make sure that the python version launched by STM32CubeIDE is the same you updated with pip?
Best regards
Jocelyn
leeana
leeanaAuthorBest answer
Jocelyn RICARD
Oct 5, 2021 9:00 AM UTC
Hi @leeana​
Great! Thank you for your feedback
Best regards
Jocelyn
