Zsan.1
Nov 3, 2020 1:20 PM UTC
Problem with SPI DMA transfer when CRC is enabled (STM32G474RE)
I need to receive SPI data from STM32G474RE master A to STM32G474RE slave B with DMA and CRC feature. DMA works in normal mode both on master and slave, which triggered by timer 2 on master A. The structure of the data frame is ADC1(16bit)+ADC2(16bit)+ADC3(16bit)+CRC(16bit). But CRCERR comes never even if the transmission is corrupted. How would I do this?
codes on master A below:
uint16_t SPI1_TX_BUFF[3] = { 0 };
 #define SPI1TxBufferSize 3
void spi1_init(void) {
	LL_SPI_InitTypeDef SPI_InitStruct = { 0 };
	LL_GPIO_InitTypeDef GPIO_InitStruct = { 0 };
	/* Peripheral clock enable */
	LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_SPI1);
	LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOA);
	LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOB);
	/**SPI1 GPIO Configuration
	 PA15 ------> SPI1_NSS
	 PB3 ------> SPI1_SCK
	 PB4 ------> SPI1_MISO
	 PB5 ------> SPI1_MOSI
	GPIO_InitStruct.Pin = LL_GPIO_PIN_15;
	GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
	GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_VERY_HIGH;
	GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
	GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
	GPIO_InitStruct.Alternate = LL_GPIO_AF_5;
	LL_GPIO_Init(GPIOA, &GPIO_InitStruct);
	GPIO_InitStruct.Pin = LL_GPIO_PIN_3;
	LL_GPIO_Init(GPIOB, &GPIO_InitStruct);
	GPIO_InitStruct.Pin = LL_GPIO_PIN_4;
	GPIO_InitStruct.Pin = LL_GPIO_PIN_5;
	/* SPI1 DMA Init */
	/* SPI1_TX Init */
	LL_DMA_SetPeriphRequest(DMA1, LL_DMA_CHANNEL_4, LL_DMAMUX_REQ_SPI1_TX);
	LL_DMA_SetDataTransferDirection(DMA1, LL_DMA_CHANNEL_4, LL_DMA_DIRECTION_MEMORY_TO_PERIPH);
	LL_DMA_SetChannelPriorityLevel(DMA1, LL_DMA_CHANNEL_4, LL_DMA_PRIORITY_HIGH);
	LL_DMA_SetMode(DMA1, LL_DMA_CHANNEL_4, LL_DMA_MODE_NORMAL);
	LL_DMA_SetPeriphIncMode(DMA1, LL_DMA_CHANNEL_4, LL_DMA_PERIPH_NOINCREMENT);
	LL_DMA_SetMemoryIncMode(DMA1, LL_DMA_CHANNEL_4, LL_DMA_MEMORY_INCREMENT);
	LL_DMA_SetPeriphSize(DMA1, LL_DMA_CHANNEL_4, LL_DMA_PDATAALIGN_HALFWORD);
	LL_DMA_SetMemorySize(DMA1, LL_DMA_CHANNEL_4, LL_DMA_MDATAALIGN_HALFWORD);
	/* SPI1_RX Init */
	LL_DMA_SetPeriphRequest(DMA1, LL_DMA_CHANNEL_8, LL_DMAMUX_REQ_SPI1_RX);
	LL_DMA_SetDataTransferDirection(DMA1, LL_DMA_CHANNEL_8, LL_DMA_DIRECTION_PERIPH_TO_MEMORY);
	LL_DMA_SetChannelPriorityLevel(DMA1, LL_DMA_CHANNEL_8, LL_DMA_PRIORITY_HIGH);
	LL_DMA_SetMode(DMA1, LL_DMA_CHANNEL_8, LL_DMA_MODE_NORMAL);
	LL_DMA_SetPeriphIncMode(DMA1, LL_DMA_CHANNEL_8, LL_DMA_PERIPH_NOINCREMENT);
	LL_DMA_SetMemoryIncMode(DMA1, LL_DMA_CHANNEL_8, LL_DMA_MEMORY_INCREMENT);
	LL_DMA_SetPeriphSize(DMA1, LL_DMA_CHANNEL_8, LL_DMA_PDATAALIGN_HALFWORD);
	LL_DMA_SetMemorySize(DMA1, LL_DMA_CHANNEL_8, LL_DMA_MDATAALIGN_HALFWORD);
	SPI_InitStruct.TransferDirection = LL_SPI_FULL_DUPLEX;
	SPI_InitStruct.Mode = LL_SPI_MODE_MASTER;
	SPI_InitStruct.DataWidth = LL_SPI_DATAWIDTH_16BIT;
	SPI_InitStruct.ClockPolarity = LL_SPI_POLARITY_LOW;
	SPI_InitStruct.ClockPhase = LL_SPI_PHASE_1EDGE;
	SPI_InitStruct.NSS = LL_SPI_NSS_HARD_OUTPUT;
	SPI_InitStruct.BaudRate = LL_SPI_BAUDRATEPRESCALER_DIV8;
	SPI_InitStruct.BitOrder = LL_SPI_MSB_FIRST;
	SPI_InitStruct.CRCCalculation = LL_SPI_CRCCALCULATION_ENABLE;
	SPI_InitStruct.CRCPoly = 4129;
	LL_SPI_Init(SPI1, &SPI_InitStruct);
	LL_SPI_SetStandard(SPI1, LL_SPI_PROTOCOL_MOTOROLA);
	LL_SPI_SetCRCWidth(SPI1, LL_SPI_CRC_16BIT);
	LL_SPI_EnableNSSPulseMgt(SPI1);
	LL_SPI_EnableCRC(SPI1);
	LL_DMA_SetDataLength(DMA1, LL_DMA_CHANNEL_4, SPI1TxBufferSize);
	LL_DMA_SetPeriphAddress(DMA1, LL_DMA_CHANNEL_4, LL_SPI_DMA_GetRegAddr(SPI1));
	LL_DMA_SetMemoryAddress(DMA1, LL_DMA_CHANNEL_4, (uint32_t) &SPI1_TX_BUFF[0]);
	LL_SPI_EnableDMAReq_TX(SPI1);
//	 LL_SPI_EnableDMAReq_RX(SPI1);
	/* Enable SPI1 */
	LL_SPI_Enable(SPI1);
	/* Enable DMA Channels */
	LL_DMA_EnableChannel(DMA1, LL_DMA_CHANNEL_4);
//	 LL_DMA_EnableChannel(DMA1, LL_DMA_CHANNEL_8);
codes on slave B below:
uint16_t SPI1_RX_BUFF[4]={0};
#define SPI1RxBufferSize 4
void spi1_init(void){
	 LL_SPI_InitTypeDef SPI_InitStruct = {0};
	 LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
	 GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_HIGH;
	 /* SPI1 DMA Init */
	 /* SPI1_RX Init */
	 /* SPI1_TX Init */
	 LL_DMA_SetPeriphRequest(DMA1, LL_DMA_CHANNEL_7, LL_DMAMUX_REQ_SPI1_TX);
	 LL_DMA_SetDataTransferDirection(DMA1, LL_DMA_CHANNEL_7, LL_DMA_DIRECTION_MEMORY_TO_PERIPH);
	 LL_DMA_SetChannelPriorityLevel(DMA1, LL_DMA_CHANNEL_7, LL_DMA_PRIORITY_HIGH);
	 LL_DMA_SetMode(DMA1, LL_DMA_CHANNEL_7, LL_DMA_MODE_NORMAL);
	 LL_DMA_SetPeriphIncMode(DMA1, LL_DMA_CHANNEL_7, LL_DMA_PERIPH_NOINCREMENT);
	 LL_DMA_SetMemoryIncMode(DMA1, LL_DMA_CHANNEL_7, LL_DMA_MEMORY_INCREMENT);
	 LL_DMA_SetPeriphSize(DMA1, LL_DMA_CHANNEL_7, LL_DMA_PDATAALIGN_HALFWORD);
	 LL_DMA_SetMemorySize(DMA1, LL_DMA_CHANNEL_7, LL_DMA_MDATAALIGN_HALFWORD);
	 /* SPI1 interrupt Init */
	 NVIC_SetPriority(SPI1_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
	 NVIC_EnableIRQ(SPI1_IRQn);
	 SPI_InitStruct.Mode = LL_SPI_MODE_SLAVE;
	 SPI_InitStruct.NSS = LL_SPI_NSS_HARD_INPUT;
	 LL_SPI_DisableNSSPulseMgt(SPI1);
	 LL_SPI_EnableIT_ERR(SPI1);
	 LL_DMA_SetDataLength(DMA1, LL_DMA_CHANNEL_8, SPI1RxBufferSize);
	 LL_DMA_SetPeriphAddress(DMA1, LL_DMA_CHANNEL_8, LL_SPI_DMA_GetRegAddr(SPI1));
	 LL_DMA_SetMemoryAddress(DMA1, LL_DMA_CHANNEL_8, (uint32_t) &SPI1_RX_BUFF[0]);
	 LL_DMA_EnableIT_TC(DMA1, LL_DMA_CHANNEL_8);
	 /* Enable SPI1 */
uint32_t rxcrc;
void DMA1_Channel8_IRQHandler(void) {
 if (LL_DMA_IsActiveFlag_TC8(DMA1)) {
 rxcrc=LL_SPI_GetRxCRC(SPI1);
		LL_SPI_DisableCRC(SPI1);
		LL_DMA_DisableChannel(DMA1, LL_DMA_CHANNEL_8);
		LL_DMA_ClearFlag_TC8(DMA1);
