SLuit.1
Problem implementing cryptographic library in stm32h747
I am using STM32H747BI MCU and I have one project to write the data to flash memory. I am using core 7 to write the data to flash. While writing, I have to encrypt the data. So I requested cryptographic library software expansion from STM32 and they provided me the software.
From that software, I copied four files:
  • stm32h7xx_hal_cryp.c
  • stm32h7xx_hal_cryp.h
  • stm32h7xx_hal_cryp_ex.c
  • stm32h7xx_hal_cryp_ex.h
After that, I put these files in respective inc and src folders and I uncommented
#define HAL_CRYP_MODULE_ENABLED  from stm32h7xx_hal_conf.h.
After doing all of these, I started to encrypt the data but in the project it could not find CRYP_HandleTypeDef .
It shows the error unknown type name 'CRYP_HandleTypeDef'.
Could anybody suggest me what the problem is because I don't know how to solve this issue as I have done all the things that needs to be done.
SLuit.1
SLuit.1Best answer
Sorry guys. I found out the answer at last. It's really hard to find some documentation about something in STM32. I finally found the getting started guide and it's working now. Here is the link if somebody have the same problem again :
https://wiki.stmicroelectronics.cn/stm32mcu/wiki/Security:Getting_started_with_the_Cryptographic_Library#Select_a_library
Pavel A.
>  I copied four files
These 4 files are not enough. they are only façade for concrete crypto modules.
Please refer to the documentation provided with the library.
This is because H747 does not have the CRYP hardware accelerator.
Use software-only variant of the crypto library or get STM32H757.
SLuit.1
SLuit.1Author
Is there any tutorial or guideline how to use software-only variant of the crypto library. I am using STM32 MCU for the first time and I tried to find the tutorial regarding encryption but I could not get any.
@Jocelyn RICARD​
SLuit.1
SLuit.1AuthorBest answer
