Nov 21, 2024 1:56 AM UTC
Is psa_generate_random() equivalent to HAL_RNG_GenerateRandomNumber()?
STM32H573 with Secure Manager provisioned, the non-secure app cannot access the RNG anymore.  Will it be ok to use Secure Manager API psa_generate_random() to replace HAL_RNG_GenerateRandomNumber()?
STeaBest answer
Nov 21, 2024 10:31 AM UTC
Hello @Thatseasy ,
yes, you can use psa_generate_random() which calls  mbedtls_psa_external_get_random(). this will result in a call from secure to the low_level_rng defined function RNG_GetBytes();
which is calling HAL_RNG_GenerateRandomNumber()
STeaBest answer
Hello @Thatseasy ,
