Aurelien1
How to process RDP regression from appplication code?
for my application I need to set RDP regression from my application code :
1) Is it possible in RDP2 to provide OEM Key (for regression) from application code in order to restore JTAG access (and perform a regression whith a user intervention)
2) Is it possible to do RDP 2 => RDP 1 from application code (using DBGMCU_DBG_AUTH_DEVICE or other way) ? if yes what is the correct process
3) is it possible to go from RDP 1 to RDP 0 or RDP 0_5?
for this part I try the following code without success (no error but no RDP Regression)
 FLASH_OBProgramInitTypeDef obConfig = {0};
 HAL_FLASH_Unlock();
 HAL_FLASH_OB_Unlock();
 obConfig.RDPKey1 = 0x11111111;
 obConfig.RDPKey2 = 0x11111111;
 obConfig.RDPKeyType = OB_RDP_KEY_OEM1;
 obConfig.OptionType = OPTIONBYTE_RDPKEY;
 HAL_FLASHEx_OBProgram(&obConfig);
 obConfig.RDPLevel= OB_RDP_LEVEL_0_5;
 obConfig.OptionType = OPTIONBYTE_RDP;
 HAL_FLASH_OB_Launch();
Should I use HAL_FLASH_OB_Launch() twice ?(I will use external memory to store prvious command)
Thanks for your help
Jacob WOODRUFFBest answer
Hi Aurelien,
This thread was flagged for a case creation by one of our community moderators but I see that a case has already been created and closed from our direct support team.
For the benefit of everyone else that may have similar issues, the expertise from our team is given below:
RDP regression ( in legacy mode ) is possible from embedded software.
But in your code, you try to provision the OEM1 key then do a regression.
The rule about key provisioning is explained in this video:
https://www.st.com/content/st_com/en/support/learning/stm32-education/stm32-moocs/stm32u5-rdp.html
https://www.youtube.com/watch?v=9Im5h5hJACM&list=PLnMKNibPkDnEkeKd_fytwc_9x2Ht2gRUn&index=2
at 6.20
Regards,
Jake
ST Support
October 5, 2022
Isn't RDP=2 PERMANENT ?
Aurelien1
Aurelien1Author
Not in my case . I don't lock RDP_2 (OEM2LOCK = 1) to allow RDP regression using OEM Key.
Aurelien1
Aurelien1Author
Does it is possible to access to DBGMCU_DBG_AUTH_HOST from application code?
I see that this register is not inside the HAL
Hi Aurelien,
at 6.20
Regards,
Jake
ST Support
