YChen.51
Jul 27, 2021 7:04 AM UTC
How to disable the ciphertext stealing of crypto library?
Hi all
My cipher text from STM32F429 crypto library(AES-CBC-256) is CTS(Ciphertext Stealing),but the cipher text can'e decrypt by openssl on my PC because the file length is not correct.
What can I do to solve it?
Thanx
Bubbles
Aug 3, 2021 6:43 AM UTC
Hi @YChen.5​ ,
the usual way to round up the length of a plaintext to a size that is conformant with the cryptographic standard is to use a technique called padding. Look up what padding is recommended in your case. You may probably use zeroes to extend the content to required length.
J
