ali rostami
Nov 9, 2022 12:44 PM UTC
How can we debug the below projects on Keil IDE? - SBSFU project - Our main project while it is ported to SBSFU
I need to debug the SBSFU project on the Keil IDE. I know there are some data about IAR and Cube but I couldn't find anything about Keil.
After that, I also want to debug my main project while it is located in slot 1.
So How is it possible?
Jocelyn RICARD
Nov 10, 2022 1:05 PM UTC
Hello Ali,
you can start debugging SBSFU and then load your application symbols using the command :
LOAD <User application axf> INCREMENTAL
Best regards
Jocelyn
