How can I verify Secure Manager Initial Attestation Certificate?
I have exported X509 certificate from STM32H573I-DK board, and checked how it is organised.
The certificate was issued by "ST CA 01 for STM32 Initial Attestation".
I would like to verify whether it is truely signed by ST's upper-level certificate.
Where can I find the upper-level certificate?
Jocelyn RICARD
Jocelyn RICARDBest answer
Hello @kato ,
Did you have a look to UM3254 chapter 4.1.2 PSA initial attestation service.
It describes the structure of the token and point to the IAR_Verifier utility.
I guess you should find your way.
The DUA certificate is provided in Utilities/Certificates of the package
Best regards
Jocelyn
Jocelyn RICARD
Hello @kato ,
Best regards
Jocelyn
katoAuthor
Thank you very much for your reply, @Jocelyn RICARD .
I have reviewed UM3254 and now understand that the upper-level certificate—in this case, the CA DUA Initial Attestation Certificate—is provided by ST to the OEM under license.
Thank you again for your kind support.
Best regards,
Kato
