ELitv.2
Jul 18, 2022 12:47 PM UTC
Hex2bin CRC and HAL STM32 CRC are not the same
Hi
I tried to generate hex2bin crc32 and then crc32 on stm32 (on words, the rest CubeMX configurations were set to default) , but they are not the same. On hex2bin i can configure big or little endianness, but the result doesn't change and i don't know the default.
Did anyone here try to conduct the same experiment and can share the insights or findings?
Thanks!​
Andrew Neil
Jul 18, 2022 1:02 PM UTC
"CRC32" just tells you that the CRC has 32 bits.
You also need to have the same generator polynomial, initial conditions, etc for the results to match.
http://www.ross.net/crc/crcpaper.html
ELitv.2
ELitv.2Author
Jul 18, 2022 1:15 PM UTC
Thank you!
​"CRC32" just tells you that the CRC has 32 bits.
Doesn't it also tell the data taken in account is 32 bit?
Will look at your link.
Thank you for your help!​
Andrew Neil
Jul 18, 2022 1:21 PM UTC
@Community member​ "Doesn't it also tell the data taken in account is 32 bit?"
No - a CRC could be applied to any block of data.
