Jmail.1
Hello, I'm curious to know how to add a secure boot feature on the STM32429I-EVAL1. I would like to allow the boot on a bootloader located in the flash memory, only if this one is known by the internal bootloader.
I'm trying to add a authentication mechanism with a symmetric key stored in the system memory but I'm not sure if it's the right way and i also don't know how to store this key in the system memory.
I read about SBSFU but not sure about it.
Kindly advise me on how could i do it please.
Thanks in advance.
TDKBest answer
October 26, 2021
It sounds like X-CUBE-SBSFU was built for something like this. Spend some time reading about it and getting the examples up and running on your board.
https://www.st.com/en/embedded-software/x-cube-sbsfu.html
TDKBest answer
October 26, 2021
November 4, 2021
Why wouldn't you use an asymmetric method where the validation/verification only needs the Public Key?
Jmail.1
Jmail.1Author
asymmetric, why not but my main issue is here that i want to not allow the user to reset the flash memory to deploy whatever he wants...
