Peter BENSCH
Peter BENSCHBest answer
Well, this could be a copy'n'paste error, for which I would like to apologise. However, only the functions and parameters in the data sheet are relevant and guaranteed.
For my L452RE it looks like this:
Peter BENSCH
Correct, in contrast to the STM32L452RE, the STM32F446 does not contain an RNG.
Does it answer your question?
/Peter
Peter BENSCH
ok thank you. do you have any instuctions on how to use wolfssl without a rng. I am struggling to get rsa encryption to run. Thank you for your time.
Peter BENSCH
Apart from switching to an STM32 with RNG, no.
There are methods of generating a little randomness with a PRNG, by reading in the chip temperature or other simple approaches, but this is far away from a certified TRNG and may even be enough for a dice, but not for current encryption techniques.
Explorer
August 10, 2024
i have the same problem did you found the solution  ?
Peter BENSCH
@fm1As mentioned before: choose an STM32 providing an RNG. If you have special requirements, you should create a new thread.
/Peter
