October 22, 2024
Cryptolibrary 4.x.x (cmox) RSA preallocated buffer
How do you know how big the preallocated static buffer should be when calling cmox_rsa_construct?
Does this depend on the RSA key size that will be used?
Does this depend on the Modular Exponentiation function that is selected (LOWMEM, MIDMEM, HIGHMEM)?
Thanks!
Jocelyn RICARD
Jocelyn RICARDBest answer
Hello @lieron ,
you should find information in the Cryptolibrary Wiki in performance page here
It provides buffer size depending on the implementation used.
Another way to do is to put a pattern in your buffer, run the algo, check size used and add a margin.
Best regards
Jocelyn
Jocelyn RICARD
Hello @lieron ,
Best regards
Jocelyn
