Wladimir
Apr 29, 2021 8:10 PM UTC
Cryptolib RSA Nucleo-L476RG working slow
Hello to all!
Using X-Cube-Cryptolib for RSA algorythm on Nucleo-L476RG board, encryption and subsequent decryption of demo message going very slow - 2 seconds, its mostly decription, i using hardware timer2 for time measuring.
Is there any ways to reduce decription time?
Best regards!
Jocelyn RICARD
May 10, 2021 8:58 PM UTC
Hi Wladimir,
ok good you solved your issue.
Regarding speed, normally clock cycles used divided by your actual frequency should lead in the resulting time with small error margin.
So, if you have same conditions as for benchmarks you should get same results.
Best regards
Jocelyn
