Andrew Neil
Jan 5, 2021 4:02 PM UTC
Can't close Lab projects - File access rights
During the workshop itself, I had some problems with some of the example files not having correct access rights to allow the workshop changes to be made.
We worked around that during the workshop.
Now I have just come back to the STM32Cube IDE; it started up with the last 2 workshop projects still open (as would be expected). But when I tried to close these projects, I got the following errors:
It seems that the whole workshop folder tree was installed with only 'Read' access for Users:
Giving 'Full Control' stopped the problems:
0693W000006Hb2WQAS.png0693W000006Hb2qQAC.pngHopefully this will be of help if anyone else is having the same problem.
But the question remains: why did the stuff get installed with these inappropriate settings?
This is on a standalone Win10-Pro.
    Jocelyn RICARD
    Jan 7, 2021 7:31 AM UTC
    Hello Andrew,
    After creating any directory you get this behavior. I mean : creator owner can modify whereas Users can only read.
    So, I guess you didn't use the same user account between package installation and usage.
    Is that the case?
    Best regards
    Jocelyn
    Andrew Neil
    Jan 15, 2021 10:39 AM UTC
    No, I used exactly the same account for installing and using - that's the strange part.
    Andrew Neil
    Jan 15, 2021 11:07 AM UTC
    I've just downloaded the latest STM32CubeIDE, and installed it.
    Now I'm getting the same again:
    0693W000007BQ60QAG.pngAgain: downloaded, extracted, and installed all with the same login.
    Jocelyn RICARD
    Jan 18, 2021 1:05 PM UTC
    Hello Andrew,
    your issue seems related to a specific Windows policy.
    I would suggest checking this with your IT
    Best regards
    Jocelyn
