Ftaht.1
Oct 1, 2021 11:00 AM UTC
Calculated CRC value does not match incoming CRC value
Hello
I'm having trouble calculating crc. I am using STM32F401 with cube ide.
The correct crc occurs on crccalc.com. But I couldn't run CRC-8 with MCU. I have looked at the examples, but when I try it gives different results.
Can you provide a working code example?
Oct 1, 2021 11:17 AM UTC
Sorry, but in what context?
I don't recall the F4 provides a programmable CRC peripheral, is this under SPI? Please elaborate on the application.
Ftaht.1
Ftaht.1Author
Oct 1, 2021 12:01 PM UTC
I'm getting the data with I2C. For example, incoming data;
0x17 0X1D 0x00 0x0A
Data is: 171D00
CRC is : 0A
I must use CRC-8, http://smbus.org/faq/crc8Applet.htm
x8+x2+x+1
i don't know how to calculate this crc-8 with mcu :(
When I calculate via http://crccalc.com, input: 171D00, result is 0A (this is ok)
I couldn't get this result when I calculated it with mcu.
I tried the library here. But the result does not match
https://stm32f4-discovery.net/2015/07/hal-library-10-crc-for-stm32fxxx/
Thanks for help
Oct 1, 2021 12:49 PM UTC
Right because the MCU has a fixed 32-bit CRC / Polynomial implementation in hardware which is entirely unusable for your application
A regular software implementation would work
