carl2399
Dec 16, 2011 5:51 AM UTC
Yagarto vs Raisonance
Posted on December 16, 2011 at 06:51
I'm using a makefile to build my application - I'm not a huge fan of IDE's.
By setting my PATH environment variable (in Win32 system) to the Raisonance toolchain everything builds fine and runs fine on my STM32F2.
By setting my PATH environment variable to the Yagarto toolchain everything builds fine (same errors and a very similar sized output) but the code does not run!
I do ''make clean, make all'' for both tests.
Put up here just in case somebody else wastes a day chasing their compiler in circles.
Yagarto is V4.6.0.
Raisonance is V4.3.2
    carl2399
    carl2399Author
    Dec 18, 2011 12:45 AM UTC
    Posted on December 18, 2011 at 01:45
    There are times when I might have liked to have a JTAG based or some other single step debugger. Fortunately the number of times I've had to write something that's that  algorithmicaly intensive is quite rare. Also with most embedded systems the edit-compile-burn-test cycle is quite fast, and it is generally not too difficult to go around that loop 15 times in an hour. (Again fortunately not too often).
