jesson
X-CUBE-VS4A -- How to pass Amazon ATS certificates?
  • August 17, 2018
  • 8 replies
  • 2231 views
1.Uncommenting one line in service_asset.c still can't work.
Request a token from Amazon website. It shows token "ANeQCyBUgoyAFxrpfsUJ" in browser.
But my STM32F769I shows below messages: Always can't pass Amazon ATS certificates.
Network : ssl_tls.c:4591 : c04337f4: x509_verify_cert() returned -9984 (-0x2700)
TLS certification error, check the Root CA : EVT_TLS_CERT_VERIFY_FAILED(0)
Open a TLS Connection     : EVT_OPEN_TLS(0)
Debug : avs_token_imp.c:462 : could not get token from amazon with code ANeQCyBUgoyAFxrpfsUJ
2.Create new project in developer.amazon.com/avs/, and get new client_id, client_secret, project_id, renew these information has the same error.
3.Check CA in default_amazon_root_ca_raw.c, ROOT CA are the same as listed in https://www.amazontrust.com/repository/, But no "Cross Certificates" and no "Other CAs"
in f/w.
What should I do to fix this issue?
    jesson
    jessonAuthor
    The detail error log is as below:(I reneamed part of clientId/clientSecret)
    Sdk : Version v1.1.1
    App : Version v1.1.1
    Debug : service_persistent_storage.c:246 : Persistent: Write Item in Flash
    Debug : platform_adapt.c:226 : going to overwrite flash memory
    Debug : platform_adapt.c:273 : Persistent: Refresh OK
    Debug : service_persistent_storage.c:310 : Read Private config
    Debug : service_persistent_storage.c:321 : Flash Store empty
    Debug : avs_lwip_network_imp.c:164 : Start the Network ...
    Debug : avs_lwip_tls_imp.c:196 : Seeding the random number generator.
    Debug : service_persistent_storage.c:227 : Read CA Root
    **** Instance *** clientId : "amzn1.application-oa2-client.042288f4357e41c4babb533b67bxxxxx" clientSecret : "a4288cc28f02c4e680e1f545935d84dda7124a7f18ca697af4985e688f0yyyyy" productId : "my_device4" serialNumber : "S/N_2818085" macAddr : { 0xE0,0xA0,0x25,0x00,0x2B,0x80 } hostName : "STVS4A Application" used_dhcp : 1 use_mdns_responder : 1 ipV4_host_addr : "***.***.***.***" ipV4_subnet_msk : "***.***.***.***" ipV4_default_gatway : "***.***.***.***" ipV4_primary_dns : "8.8.8.8" ipV4_secondary_dns : "8.8.4.4" urlNtpServer : "0.fr.pool.ntp.org" urlEndPoint : "avs-alexa-na.amazon.com" redirectUri : "http://stvs4a/grant_me" cpuID : "STM32F769I cut 1.1" toolChainID : "GCC" profile : 2:AVS_PROFILE_NEAR_FIELD initiator : 2:AVS_INITIATOR_TAP_TO_TALK portingAudioName : "bsp-audio" netSupportName : "LWIP_eth" alexaKeyWord : "ALEXA" synthesizerSampleRate : 24000 synthesizerSampleChannels : 2 useAuxAudio : 1 auxAudioSampleRate : 16000 auxAudioSampleChannels : 1 recognizerSampleRate : 16000 eventCB : 0x08014BED eventCB_Cookie : 0x00000000 persistentCB : 0x08014BE9 memDTCMSize : 128 memPRAMSize : 147 memNCACHEDSize : 0 **** Audio *** audioInLatency : 0 audioOutLatency : 0 audioMp3Latency : 0 initVolume : 60 freqenceOut : 48000 buffSizeOut : 0.00 freqenceIn : 16000 buffSizeIn : 0.00 chOut : 2 chIn : 1 platform.numConfig : 0 platform.numProfile : 0************ Start ***************
    14:32:32 : Mem DTCM 128 KB -> 100.0%
    10:44:16 : Mem PRAM 147 KB -> 100.0%
    10:44:16 : Mem HEAP 3959 KB -> 96.7%
    Debug : avs_lwip_network_imp.c:103 : IpAdress = 192.168.101.105
    11:35:28 : Recognizer task starts : EVT_AUDIO_RECOGNIZER_TASK_START(0)
    13:07:12 : Synthesizer task starts : EVT_AUDIO_SYNTHESIZER_TASK_START(0)
    15:55:44 : State task starts : EVT_STATE_TASK_START(0)
    Debug : avs_state_imp.c:412 : Enter Start HTTP2
    Debug : avs_state_imp.c:428 : Leave Start HTTP2
    00:00:00 : Connection task starts : EVT_CONNECTION_TASK_START(0)
    21:17:52 : Reset Http2 : EVT_RESET_HTTP(0)
    Debug : avs_token_imp.c:138 : Wait for a token available
    15:55:44 : MP3 task starts : EVT_MP3_TASK_START(0)
    04:05:17 : Network time synchronized : EVT_SYNC_TIME(1)
    04:05:17 : Refresh Token task starts : EVT_REFRESH_TOKEN_TASK_START(0)
    Debug : service_persistent_storage.c:185 : Persistent: Looking from token in Flash
    Debug : service_persistent_storage.c:189 : Flash doesn't contain a valid token yet
    Warning : avs_token_imp.c:517 : RefreshToken is null... can't get a token from a previous session from persistant memory
    Debug : avs_token_imp.c:460 : could not get token from amazon with code
    04:05:17 : Read persistent token : EVT_READ_TOKEN(0)
    04:05:17 : Wait a token : EVT_WAIT_TOKEN(0)
    Debug : service_authentication.c:291 : Auth Server Send :
    HTTP/1.1 302 Found
    Location: https://www.amazon.com/ap/o...{ "alexa:all": { "productID": "my_device4", "productInstanceAttributes": { "deviceSerialNumber": "S/N_2818085" } } }&response_type=code&redirect_uri=http://stvs4a/grant_me&state=stm32F7_RqGC Content-type: text/html
    04:05:27 : Wait a token : EVT_WAIT_TOKEN(0)
    04:05:57 : Token renew via the web page : EVT_RENEW_ACCESS_TOKEN(0)
    Debug : avs_lwip_tls_imp.c:293 : Connecting to tcp/api.amazon.com/443...
    04:05:57 : Wait a token : EVT_WAIT_TOKEN(0)
    Debug : avs_lwip_tls_imp.c:304 : Setting up the SSL/TLS structure
    Debug : avs_lwip_tls_imp.c:347 : Performing the SSL/TLS handshake
    Network : ssl_tls.c:4587 : 0xc043681c: x509_verify_cert() returned -9984 (-0x2700)
    Debug : 04:05:58 : TLS certification error, check the Root CA : EVT_TLS_CERT_VERIFY_FAILED(0)
    04:05:58 : Open a TLS Connection : EVT_OPEN_TLS(0)
    avs_token_imp.c:460 : could not get token from amazon with code ANkbcVrAdaJvYuFpLhGc
    Any suggestion to fix this problem is appreciated!
    jesson
    jessonAuthor
    My Sequence is: (have step3 or haven't step3 results the same error)
    1.enable the new Amazon ATS certificates by uncommenting this line in service_asset.c
     {"default_amazon_root_ca", default_amazon_root_ca, sizeof(default_amazon_root_ca)},
    2.Enable Messages in avs_base,h
     AVS_TRACE_LVL_DEFAULT = (AVS_TRACE_LVL_ALL)
    3.Create a Project in developer.amazon.com, update MY_CLIENT_ID, MY_CLIENT_SECRET_ID, MY_CLIENT_PRODUCT_ID values from "Security Profile > Web" page
    Add "http://stvs4a/grant_me" in "Allowed return URLs"
    4.Use trueStudio build code, select \Projects\STM32F769I-Discovery\Applications\STVS4A\SW4STM32\STVS4A_BSP_LWIP
    Binary file outputs: STM32_AVSdemo_F769.elf
    5.Use STM32CubeProgramer:
     5-1.Connect Device
     5-2.Option:Unlocked DBANK
     5-3.Select STM32_AVSdemo_F769.elf, set Verify programming.
     5-4.Select Available external loaders:MX25L512G_STM32F769I_DISCO
     5-5.Full chip erase
     5-6.start programming
    6.Plug Network from RJ45, Hardware Reset Device
    7.Open PC's browser, enter Device's local ip, log in Amazon, redirects to a token url. rename with the local ip in front of the url
    8.Browser shows:Got the Alexa access token : xxxxxxx...
     But Message shows
     "Network : ssl_tls.c:4587 : 0xc0436874: x509_verify_cert() returned -9984 (-0x2700)"
     "TLS certification error, check the Root CA"
     Error : avs_state_imp.c:450 : Start time-out > 120 secs
    Emmanuel_C
    don't change service_asset.c for the moment and it will connect.
    This piece of code was written, based on Amazon message telling that the connection way would be updated mid June. The connection part itself was tested on a test server, but the full use case could not be executed at that time.
    Currently the legacy way still works.
    We'll work on this evolution and make it work for next release.
    Emmanuel
    jesson
    jessonAuthor
    I remove step1.
    A Token is already available
    But still get another Error as below:
    Debug : avs_http2_imp.c:215 : http2ClientConnect FAILED with error : 1 : Retry
    The LCD always shows: Resolving Amazon...
    Firmware returns error (HTTP2_STATUS_FAILURE) in
    Http2Status avs_porting_http2_client_connect(AVS_instance_handle * pHandle)
    >> Http2Status err = http2ClientConnect(pHandle->hHttpClient, &serverAddr, sizeof(serverAddr));
    Error : avs_lwip_tls_imp.c:359 : mbedtls_ssl_handshake FAILED :  -0x4c
     09:55:56 : Open a TLS Connection     : EVT_OPEN_TLS(0)
    Debug : avs_token_imp.c:460 : could not get token from amazon with code ANzqtPBvLEoybtUstaAP
     09:56:07 : Wait a token          : EVT_WAIT_TOKEN(0)
    Network : ssl_tls.c:4587 : 0xc04367ac: x509_verify_cert() returned -9984 (-0x2700)
    Debug : avs_lwip_tls_imp.c:368 : Verifying peer X.509 certificate
    Debug : avs_lwip_tls_imp.c:375 : mbedtls_ssl_get_verify_result FAILED
     ! The certificate is not correctly signed by the trusted CA
    Debug : avs_token_imp.c:254 : Token: Header
    POST /auth/o2/token HTTP/1.1
    Host: api.amazon.com
    Content-Type: application/x-www-form-urlencoded;charset=UTF-8
    Content-Length: 242
     09:56:11 : Open a TLS Connection     : EVT_OPEN_TLS(1)
    Debug : avs_token_imp.c:256 : Token: Body
    grant_type=authorization_code&code=ANzqtPBvLEoybtUstaAP&client_id=amzn1.application-oa2-client.042288f4357e41c4babb533b67bxxxxx&client_secret=a4288cc28f02c4e680e1f545935d84dda7124a7f18ca697af4985e688f0yyyyy&redirect_uri=http://stvs4a/grant_meDebug : avs_token_imp.c:138 : Wait for a token available
    Debug : avs_token_imp.c:301 : Token: response header
    HTTP/1.1 200 OK
    Server: Server
    Date: Thu, 30 Aug 2018 09:56:12 GMT
    Content-Type: application/json;charset=UTF-8
    Content-Length: 1212
    Connection: keep-alive
    x-amzn-RequestId: ed8754c0-ac3a-11e8-82a8-11a3f5ccf6d0
    X-Amz-Date: Thu, 30 Aug 2018 09:56:12 GMT
    Cache-Control: no-cache, no-store, must-revalidate
    Pragma: no-cache
    Vary: Accept-Encoding,User-Agent
    Debug : avs_token_imp.c:323 : Token: Response body
    { "access_token":"Atza|IwEBIN1G0om_AEQXo4a9XwdOTXwU2_GYKgK2ADTnBkwtwSr7Y6XumcBH7j4HXh_CxEPll0X6YsFPmqSTrjCPbbHjmMJaYn9C2PnBULQKPOV7TasQIOxggsIbXSmKWwFxFRMl9pxg_jaLUN_ooMaJqsNyZhWnHcTt2AODL5bTF3dbykkbsf900PaFNdUFOboHg0RkRgzvY-oaPrtMrZ4zh8jrjb9OssbrT5TMAzZdZfcxDiHFCpqs9I9qoKeX8NJr6YiZgKdnPnRs7gHowkALEHZQXI9Fl_86hoebCpKhRIGpjzwJR1XJp3HzX8PVEuvsvt50ttd7Y6pZ9Tknp8yyLpXLMqqmSceu4Ey6cxbds6jQ4d8xoxQwsb3LpVxOVfwTXrP2HnGoCVBW68QIwMOHgxXhWWRzbQc6iv-TVLh8dKY3_kPZZuUkEnkfuqRNHSYIattW-DapI3i8RTK8CUQ8Ewye7hEMJz_-CcimbJ--v7r9DUtyw22ojnqNeO-QgzTrbCUe2JJcCaiFjfZdRplE0VOTpk127r1mkWs7wld3pXyxzHddGw", "refresh_token":"Atzr|IwEBIBhatC_XrM6UZKORNxc14CsHy0fF3AuJmLb5120JEUivHgQQb6pZt47wE17RwZQVBL6NTFNwo0mIH99qad7TIVmojCOkqkuMOV1hUSsvi17Pkay7PFqgEFDr8sRcupcJfu2UZ4L7j31GEjV50skqyLZTPzES_n8UCGhNHWFEFO7gM5d-zkqSrREzsdTM20ew3MVNUdNzd4i340BWDBfss9EXyq7_kIdcugWXUfifinGXhg4pmx_3SG7fvb4EAl7ys5LDanKayQq1LlvfNhUmAyRXuT6CPrqjj3AG3mjC6LtbcqyiCAWDVGt3iBMyPhMEbkuRaW0kzvvXBJotLHZO4fzDS-JvZd7ClbekYLVAJrM0QGODfjGRoiDmS7nb7YkPjTU7fXv-D5jBDa9nUYUrGbZ_qfxIOWDr1jDnZLDiAaCyKaZaTOjC2ki9a9hiV2tPyc3zyAWGr0_FJ2smp5LgvRbazdbIh5IdquCuK77MunU3MArPhWnRDhf_jlPaZZGgLUU8ymLJUcIHbbCdb_SwrcwZs-PtmdXQKkMtEFyDApAHmw", "token_type":"bearer", "expires_in":3600}Debug : service_persistent_storage.c:206 : Persistent: Write token in Flash
    Network : ssl_tls.c:2846 : 0xc04367ac: mbedtls_ssl_flush_output() returned -69 (-0x0045)
    Network : ssl_tls.c:4134 : 0xc04367ac: mbedtls_ssl_write_record() returned -69 (-0x0045)
    Network : ssl_tls.c:7197 : 0xc04367ac: mbedtls_ssl_send_alert_message() returned -69 (-0x0045)
     09:56:13 : Write persistent token     : EVT_WRITE_TOKEN(1)
    Debug : avs_token_imp.c:569 : Time 87009
     09:56:13 : Token Valid !         : EVT_VALID_TOKEN(0)
    Debug : avs_token_imp.c:143 : --------Got a token-----------
    Debug : avs_http2_imp.c:205 : Use token (bearer) = Bearer Atza|IwEBIN1G0om_AEQXo4a9XwdOTXwU2_GYKgK2ADTnBkwtwSr7Y6XumcBH7j4HXh_CxEPll0X6YsFPmqSTrjCPbbHjmMJaYn9C2PnBULQKPOV7TasQIOxggsIbXSmKWwFxFRMl9pxg_jaLUN_ooMaJqsNyZhWnHcTt2AODL5bTF3dbykkbsf900PaFNdUFOboHg0RkRgzvY-oaPrtMrZ4zh8jrjb9OssbrT5TMAzZdZfcxDiHFCpqs9I9qoKeX8NJr6YiZgKdnPnRs7gHowkALEHZQXI9Fl_86hoebCpKhRIGpjzwJR1XJp3HzX8PVEuvsvt50ttd7Y6pZ9Tknp8yyLpXLMqqmSceu4Ey6cxbds6j...
     09:56:14 : Amazon resolved        : EVT_HOSTNAME_RESOLVED(0)
    j2
    Debug : avs_token_imp.c:132 : A Token is already available
    (Repeat...)
    Emmanuel_C
    Make sure you have updated the external flash content and that it doesn't contain anymore the default_amazon_root_ca section
    jesson
    jessonAuthor
    Hi Emmanuel_C,
    Yes, I did full chip Erase by STM32CubeProgramer before download firmware.
    I use default setting to run Sdk v1.1.1 and v1.1.0, both has the same log, and LCD is always showing "Resolving Amazon..."
    I only change clientId, clientSecret, productId, which are get from the project I created in Alexa's developer web site.
    Use default clientId, clientSecret, productId has the same result also.
    ======== Below log with default debug settings, for detail error please refer my previous comment ============
    Hello STVS4A
     03:24:48 : Synthesizer task starts    : EVT_AUDIO_SYNTHESIZER_TASK_START(0)
     06:34:22 : Network time synchronized   : EVT_SYNC_TIME(1)
     06:34:22 : Refresh Token task starts   : EVT_REFRESH_TOKEN_TASK_START(0)
     06:34:22 : Read persistent token     : EVT_READ_TOKEN(0)
     06:34:22 : Wait a token          : EVT_WAIT_TOKEN(0)
     06:35:14 : Wait a token          : EVT_WAIT_TOKEN(0)
     06:35:24 : Token renew via the web page  : EVT_RENEW_ACCESS_TOKEN(0)
     06:35:24 : Wait a token          : EVT_WAIT_TOKEN(0)
     06:35:27 : Open a TLS Connection     : EVT_OPEN_TLS(1)
     06:35:27 : Amazon resolved        : EVT_HOSTNAME_RESOLVED(0)
     06:35:27 : Write persistent token     : EVT_WRITE_TOKEN(1)
     06:35:27 : Token Valid !         : EVT_VALID_TOKEN(0)
     06:35:28 : Amazon resolved        : EVT_HOSTNAME_RESOLVED(0)
    (Repeat...)
     06:35:30 : Amazon resolved        : EVT_HOSTNAME_RESOLVED(0)
    jesson
    jessonAuthor
    Except doing internal and external flash full chip erase.
    I also remove codes relative default_amazon_root_ca:
    1.service_assets.c -- assets_header_flash_base
    2.service_persistent_storage.c -- service_persistent_init_default
    After build, no "default_amazon_root_ca" relative codes can be found in output.map.
    But still get the same log. LCD also always shows "Resolving Amazon...".
    There's an error returned in avs_porting_http2_client_connect > http2ClientConnect.
    How should I do to fix this error?
    Thank you.
    Edwin Reich
    November 2, 2018
    Has anything been resolved with this issue?
    I am having a similar issue.
    I followed the steps in the response above and I still am getting a certificate error.
    I have tried it with and without the default certificate commented out.
    Here is my log output:
    Hello STVS4A
    Debug : service_persistent_storage.c:316 : Flash storage empty
    Debug : service_persistent_storage.c:233 : Flash storage empty
    ************ Start ***************   : 0.0002283D"ATOR_TAP_TO_TALK0x80 }1893663a011464328487abaf660b47c6"
     08:06:24 : Mem DTCM  128 KB -> 100.0%
     08:06:24 : Mem PRAM  147 KB -> 100.0%
     08:06:24 : Mem HEAP  3959 KB -> 96.7%
    Debug : avs_lwip_network_imp.c:103 : IpAdress = 192.168.254.141
     08:06:24 : Recognizer task starts     : EVT_AUDIO_RECOGNIZER_TASK_START(0)
     08:06:24 : Synthesizer task starts    : EVT_AUDIO_SYNTHESIZER_TASK_START(0)
     08:06:24 : State task starts       : EVT_STATE_TASK_START(0)
     08:06:24 : Connection task starts     : EVT_CONNECTION_TASK_START(0)
     08:06:24 : Reset Http2          : EVT_RESET_HTTP(0)
     08:06:24 : MP3 task starts        : EVT_MP3_TASK_START(0)
    HTTP/1.1 302 Found
    Location: https://www.amazon.com/ap/oa?client_id=amzn1.application-oa2-client.8733cd06a05b40a695918f68xxxxxxxx&scope=alexa:all&scope_data={"alexl
     21:46:07 : Network time synchronized   : EVT_SYNC_TIME(1)
     21:46:07 : Refresh Token task starts   : EVT_REFRESH_TOKEN_TASK_START(0)
    Debug : service_persistent_storage.c:182 : Flash storage empty
     21:46:07 : Read persistent token     : EVT_READ_TOKEN(0)
     21:46:07 : Wait a token          : EVT_WAIT_TOKEN(0)
    Debug : avs_lwip_tls_imp.c:293 :  21:46:13 : Token renew via the web page  : EVT_RENEW_ACCESS_TOKEN(0)
     21:46:13 : Wait a token          : EVT_WAIT_TOKEN(0)
     21:46:26 : Open a TLS Connection     : EVT_OPEN_TLS(1)
    Content-Length: 242
    grant_type=authorization_code&code=ANgrptrvVKbQRFACwSjd&client_id=amzn1.application-oa2-client.8733cd06a05b40a695918f68xxxxxxxx&client_secret=37r
    HTTP/1.1 200 OK
    Server: Server
    Date: Fri, 02 Nov 2018 21:46:28 GMT
    x-amzn-RequestId: c0be5d2d-dee8-11e8-b073-8ff209c64517
    X-Amz-Date: Fri, 02 Nov 2018 21:46:28 GMT
    Pragma: no-cache
    Vary: Accept-Encoding,X-Amazon-CDN-Cache,User-Agent
    x-amz-rid: P7KA4FZW9XJJB4ZZ5SJ6
    {"access_token":"Atza|IwEBIA7AMugqmZ-9Dq54B_YAxve5JvVLX17O1kvFpaYmDSz4rz26669NdDUuMtG_rKrlMXiaYFwyj-6Nj82Tmzo4C0Z-CvSjrefKhleMZXIdGlQvwda0e-KvVPh
     21:46:27 : Write persistent token     : EVT_WRITE_TOKEN(1)
    Debug : avs_token_imp.c:569 :  21:46:27 : Token Valid !         : EVT_VALID_TOKEN(0)
    Time 39790
    Debug : avs_http2_imp.c:205 : Use token (bearer) = Bearer Atza|IwEBIA7AMugqmZ-9Dq54B_YAxve5JvVLX17O1kvFpaYmDSz4rz26669NdDUuMtG_rKrlMXiaYFwyj-6Nj.
     21:46:34 : Amazon resolved        : EVT_HOSTNAME_RESOLVED(0)
    This repeats indefinitely:
    Emmanuel_C
    Please try version 1.1.2.
    It should solve your problem
