Paul J Kim
Feb 23, 2017 3:59 AM UTC
X-CUBE SPIN2 firmware zip file is corrupted. I can not unzip it.
Posted on February 23, 2017 at 04:59
I have X-NUCLEO-IHM02A1 expansion board.
And downloaded the its firmware file of X-CUBE-SPN2.
The file can not be unzipped.
Please check the zip file and upload latest one as soon as possible.
thanks
    Tesla DeLoreanBest answer
    Feb 23, 2017 5:07 AM UTC
    Posted on February 23, 2017 at 06:07
    Might use a newer ZIP method, had to load a new version of WinRAR, but archive does test out as valid.
    Mirrored here
    https://drive.google.com/open?id=0B7OY5pub_GfIZi1VNDF3dnI0cDQ
    Mirrored here
    Emmanuel L_O
    Feb 24, 2017 7:43 AM UTC
    Posted on February 24, 2017 at 08:43
    I also tried to download the 'en.X-CUBE-SPN2_firmware.zip' which is available at the
    https://my.st.com/content/my_st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-software/x-cube-spn2.license%3d1487920566515.html
    page.
    I could unzip and load the FW project without problem. Perhaps you met some dowload problems?
    Can you just try to redownload it? If you still have the problem, can you specify your configuration?
    Paul J Kim
    Feb 24, 2017 8:37 AM UTC
    Posted on February 24, 2017 at 09:37
    Thanks Clive One,
    After I updated WinRAR latest version, it works fine.
    But the zip file couldn't be extracted by normal unzip feature embedded in Window OS like Window XP and Window 7 at least. I have attempted an extraction of the zip file in those two Window machines but in fail.
    Thanks all folks.
