X-Code Audio Problem
I am using the Stm32f446RC MCU model for a sound application. I am using the X-Cube Audio library (STM32CubeExpansion_Audio_V1.1.1), which claims to support F4 and F7 versions. I want to control the audio levels using the SVC app, but when I call the svc_reset function, I receive an error with code -7 (SDR_BAD_HW). This issue is not limited to this function, as I encounter the same error in other applications as well. Can you assist me in resolving this problem?
