lming.0
Feb 27, 2019 8:51 AM UTC
why the MCU stm32L011F3 has so small flash memory?
 the MCU stm32L011F3 has only 8k flash ,and without standard peripheral library, only HAL and LL library, as i know, the Optimization of HAL is lowest all of them, and LL driver is little Readiness,
can any one tell me, is that the HAL driver can execute successfully in stm32L011F3 ?
thanks a lot!
After Forever
After ForeverBest answer
Senior III
Feb 27, 2019 9:26 AM UTC
If you want to use HAL then choose another model with bigger flash. 8K flash models are obviously targeted for simple applications written in CMSIS or even assembly.
You don't buy a little 2-place car and then complain that your entire family can't have a ride.
After Forever
Senior III
lming.0
lming.0Author
Feb 27, 2019 10:15 AM UTC
thank you for your reply, i understand
AvaTar
Senior III
Feb 27, 2019 9:56 AM UTC
Flash is one of the most expensive components on the silicon, both in size and in costs.
There are many commercial mass market projects that screw Cube/HAL, and go for the cheapest MCU that does the job.
lming.0
lming.0Author
lming.0
lming.0Author
en ok,
