VPras
why external crystal oscillator not working in STM32H7?
  • November 29, 2019
  • 7 replies
  • 3090 views
I am using STM32H7 Nucleo board. I soldered an external 25MHz crystal oscillator with 22 pf capacitors(Load capacitance of crystal =20pf) but the controller doesn't seem to work on 25Mhz crystal oscillator. I tested this by blinking an LED at 1 seconds but it is taking much longer time than usual. Also i tried replacing the crystal. although the internal oscillator HSI works fine. what could be the issue ?
Vimal
waclawek.jan
Isn't there a solder bridge from the STLink's MCO, which has to be disconnected?
Refer to the Nucleo schematics/manual.
VPras
VPrasAuthor
Thank you. Issue is solved
waclawek.jan
Can you please tell us what was the problem?
