mhelyar
Sep 28, 2018 11:39 AM UTC
Why does dynamic allocation make my program so big?
Before you say it, I know dynamic allocation is usually a bad idea with embedded software, this is more of a technical question.
If I create a new blank C++ project based on my Nucleo-L152RE in SW4STM32, the "text" portion of my compiled project read by the "size" command is about 1kB. If I then add the lines:
	int* p = new int;
	delete p;
text size becomes 75kB. data and BSS are basically unaffected.
Why is it so?
    waclawek.jan
    Sep 28, 2018 12:00 PM UTC
    .text is code, so it's the libraries pulled in. Look at the mapfile.
    Bob S
    Sep 28, 2018 3:40 PM UTC
    Perhaps new pulls in exception handling code? As Jan said, check the map file.
    Sep 28, 2018 4:52 PM UTC
    and frankly pulling in anything the constructors/destructors touch or are dependent on
