SMand.2
While setting up the clock, if I set PLLM as 8 and PLLN as 360 , it gives same result as when I set PLLM as 4 and PLLN as 180, so what difference does it makes.
  • January 30, 2023
  • 827 views
gbm
If both sets of values lie within the allowed range (including the VCO max frequency) - there is not a big difference. Higher VCO freq will result in higher power consumption by PLL.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
January 30, 2023
Depends where the sweet-spot is for the PLL comparison frequency. For the F2/F4 I think it was suggested in the 1-2 MHz region.
Also the VCO likely has a preferred operating range, ie 100 - 432 MHz.
Check the DM and RM
Typically you divide down the VCO frequency to get a square wave into the MCU
